Thread: Spray foam
    Spray foam
    Hi all,
    I am looking to foam in sections on my kit and would like to use spray foam. I know to use closed cell foam, but question what type. I see that the semi ridged spray foam used for exterior windows is rated to 240 degree F. I am thinking that if my interior gets to that temperature, I have other issues besides worrying about the foam burning. I want to foam in the roof fiberglass to the Fiero and to foam up the rear deck area after the firewall and the B-pillars.
    Questions:
    - What type of semi ridged spray foam to use?
    - Would exterior home grade foam used for sealing windows not work?
    - Should I spend a lot more for marine grade foam?
    Nov 2005
    1,114
    Re: Spray foam
    Brastic,
    I use the foam that is designed and intended for those purposes. You can buy automotive grade foams from your local paint and body supplier. I prefer FUSOR but 3M, Norton and the likes all work well. You can get rigid and non-rigid, some with bonding strength some without, etc. These are used to replace the factory foam when the shop cuts off and replaces a qtr panel or truck bedside. I am not talking about bonding adhesive..that's available from the same suppliers BUT they also sell Foam..
    Bart
    Re: Spray foam
    Thank you.
    Senior Member sactodreamer's Avatar
    Sacramento, CA
    2,262
    Re: Spray foam
    Shane,
    I got your vm around 10:30 pm.....I'm guessing you found your answer, hahahaa! I'll ask the wife in the morning about next Saturday. (21st correct?)
    Ron
  1. Autobody guy /waterbased paint spray gun question.
    By Daleford in forum Technical Discussion & Question
    Last Post: 10-03-2010, 09:14 PM
  2. Spray Paint Touch Ups
    By jdinner in forum General Kitcar Chat
    Last Post: 08-07-2004, 05:03 PM
  3. Best spray glue?
    By GSXRBOBBY in forum Technical Discussion & Question
    Last Post: 07-23-2004, 04:23 PM
  4. how to spray
    By disilva in forum Technical Discussion & Question
    Last Post: 03-26-2004, 09:59 AM
  5. Foam for carving
    By Don in forum Technical Discussion & Question
    Last Post: 07-10-2003, 11:28 AM
