Page 30 of 32 FirstFirst ... 202829303132 LastLast
Results 291 to 300 of 319
Thread: F40 Slow but worth it.....BUILD
  1. #291
    23
    Any progress? I hope you kept the replica and are still chipping away?
  2. #292
    Hi all,
    I wish there was an update but unfortunately work and other commitments mean that i havent touched the project for a long time but the decision has been made to keep it and to one day finally finish it!
  3. #293
    Hi all,
  4. #294
  5. #295
  6. #296
    3,398
    Looking amazing;
    Good to see you are back at it. There are several of us in the same timeline for getting time to get out to the garage and finish our projects. Life gets in the way of a good time a lot.....
    looking amazing so hopefully you are able to keep it up for a bit.
  7. #297
    Hi Don,
    Thanks for the comment,
    Life can be very up and down at times! but at the moment it seems to be going in a much more positive direction. I have a job building race cars again and doing it all day really pushes me to finish my own stuff more.
    The last few months have seen quite a change in the f40 now, as you can see in the pictures the tub is now bonded together and the majority of the cab rear bulkhead has been finished. I have layed up the reare wheel tub since these pictures so next step is to finish the left hand rear arch and a little work on the L/H cab window and vent. Then the plan is to lift the shell off its current table and ive bought a chassis table so that will come into the workshop and my Esprit chassis will be bolted to that them my body can be fitted to the chassis.
    Once the fitment is sorted i have already bought a roll of carbon/kevlar hybrid weave to skin the inside of the shell. once all this is bonded in i have also bought a tube bender so i can design and build a prototype roll cage that will also bolt to the chassis. This will be tacked together inside the shell so i can cut it out of the body later when the molds are done then a jig can be made. Eventually the roll cage will bebuilt and bonded into the shell during construction.
    Final stage is to then buy the custom wheels and tires to final check all clearences and to paint the shell. Then i can finally start to make the molds!
  8. #298
    3,398
    Like I said, amazing work and looking forward to more updates. Keep it up.
  9. #299
    Senior Member mera308gts's Avatar
    Jun 2008
    446
    Amazing craftsmanship PlasticFantastic, as a former replica F40 guy this is a huge leap forward and will bring the replica F40 movement back!
    Keep up the progress,
    Dana
  10. #300
    Hi all,
    Thank you mera308gts for the kind words,
    Only a small update but ive been working on the inner wheels arch lips and rear tire clearence. In the pictures im using an original pzero 335/35/17 just to give me a guide for clearences but i plan to use 345/35/19 when i order wheels and tires.
    Most of the shaping is done on the inner arch i now need to work on finalising the arch lip.
  1. slow forum download
    By dratts1 in forum General Kitcar Chat
    Last Post: 09-28-2010, 05:57 PM
  2. Slow Loading Site?????
    By Goldie in forum General Kitcar Chat
    Last Post: 10-08-2008, 10:47 PM
  3. Slow build diary
    By sactodreamer in forum General Kitcar Chat
    Last Post: 10-15-2005, 01:37 AM
  4. Site very, very slow again.
    By LarryBud in forum Off-Topic
    Last Post: 12-15-2004, 03:12 PM
  5. Forum really really really slow?
    By AutoMX in forum Off-Topic
    Last Post: 12-07-2004, 01:53 AM
