Thread: HOT KNIFE & HOT WIRE FOAM CUTTERS
    2,981
    I just got these i will try them out monday
    12" hot wire foam cutter an a hot knife for shaping
    http://www.youtube.com/watch?v=V7dinmZU9VE
    http://www.youtube.com/watch?v=jPO9_Qb9eaI
    http://members.fortunecity.co.uk/slmohr/rcinterest2.htm
    Feb 2004
    669
    Re: HOT KNIFE & HOT WIRE FOAM CUTTERS
    Quote Originally Posted by ITALIANKNIGHTRIDER
    Don't snort the fumes. Don't touch the hot parts.
    Get a MSDS on the product you intend on hot cutting.
    There is foam - and then there is foam. Polystyrene foam smoke ain't too bad,
    but polyurethane foam smoke will give you a dirt nap.
    Hot-wiring should be done in a well-ventilated room while wearing a respirator. The respirator protects you
    while cutting, the ventilation protects you after you remove the respirator. You should use 'organic vapor' cartridges.
    Anything less is foolish.... IMHO
    387
    I agree here. I wouldn't use a hot tool of any kind on any foam. It is too easy to cut with a knife with a serrated blade to take the chance with a hot blade.
    2,981
    i understand the concern , an yes i haqve a very large fan an its a open area , the students in this class room at MIT look an appear to be o k ,it is a special or certain type of wire used to slice it up ,thank you both for looking after my safety
    http://techtv.mit.edu/videos/2175-le...h-dave-wallace
    nzo replica dash board
    cut with a hot wire
    Senior Member jack999's Avatar
    Sep 2004
    319
    ??? I thought turmite cnc'd that?.. if not that looks good for hot wire.
    2,981
    Quote Originally Posted by Raptor X
    No it was cut thru turmite with a large hot wire cutter ,this is our nzo dash plug
    this is the rest of the parts of the dash 3d file
    Feb 2005
    742
    I thought I might ought to reply to this thread since it has been a while since I have posted.
    I kinda need to clear some things up for IKR since none of these delays were his fault, and honestly they were not mine either, unless someone considers cancer "fault".
    My wife, who is also my best friend, has battled cancer since Apr of 08. We thought it was gone but it came back in Aug of 09, and she went through chemo for 9 months only to be told the chemo quit working. We found out about a month ago, that the FDA (US food and drug) had taken the chemo off the market since it did not work. Wasted 9 months! Anyway, they have tried two more chemos and the last one nearly took her life.
    Now with all that said, I had the foam wired for IKR and did a lot of computer time to get the 3d model ready for wire cutting. It is just like anything else. There are trade offs, but for straight line or gentle arcs, the wire out performs a milling head 10-1! Speed is not comparable. The trade off is, you have to spend the time on the computer to get the model sliced up with a wire frame re built so it can be cut in the wire cutter.
    Mike
    Aug 2007
    197
    well wishes to your wife from me and the family, my mum is currently undergoing chemo so I feel for you and yours, looking forward to an all clear for both of the people we care about.
    Kindest regards shane
    p.s good to hear from you again
  1. Wire corrosion issue and fix?
    By FerrariXXXman in forum Technical Discussion & Question
    Last Post: 11-20-2009, 01:03 AM
  2. need a wire harness
    By GSXRBOBBY in forum The Mall
    Last Post: 05-31-2005, 07:54 PM
  3. Not really a wire mesh but...
    By GSXRBOBBY in forum Technical Discussion & Question
    Last Post: 02-15-2004, 03:19 PM
  4. This wire?
    By lovef501 in forum Technical Discussion & Question
    Last Post: 06-06-2003, 10:23 PM
  5. 5 Wire Actuators
    By janice_ho in forum Technical Discussion & Question
    Last Post: 09-13-2002, 06:23 AM
