Results 1 to 2 of 2
Thread: Question about fiberglass panels (how much to use for a panel)
    Jan 2006
    121
    I am beginning to experiment with fibreglass. First i am going to start with fabricating small pieces, pieces that have curved edges, etc, just to know what it is to work with fibreglass. How much fibreglass do i have to use to make a piece that can be used as a "panel" for a kitcar. What i want to say is, how thick does a panel have to be in order to have enough stiffness.
    grtzz
    blackpass
    383
    Re: Question about fiberglass panels (how much to use for a panel)
    The necessary thickness will depend on where the panel is to be used. If it is structural and will have to support a load it will need to be thicker than if is just a covering panel. I usually shoot for about 3/16 thick for structural panels, cover panels can be thinner. Try and use only enough resin to wet the mat and cloth. More resin actually makes the final part weaker as resin has no real strength and is only a matrix to bind the fiberglass fibers together. More resin will also make the part heavier than necessary.
  1. I need fiberglass panel advice. Please Help before I goof it up!
    By MacGyver in forum Technical Discussion & Question
    Last Post: 07-30-2011, 10:08 AM
  2. Fiberglass panels Illegal in Australia?????????????
    By ll210 in forum Technical Discussion & Question
    Last Post: 09-15-2009, 09:15 AM
  3. rubber strips between fiberglass panels
    By Brastic in forum Technical Discussion & Question
    Last Post: 03-11-2008, 03:14 PM
  4. AD 355 build question aligning body panels
    Last Post: 04-04-2006, 07:21 PM
  5. will this work for fiberglass panels?
    By 308fiero in forum Technical Discussion & Question
    Last Post: 09-12-2004, 08:14 PM
