Page 13 of 13 FirstFirst ... 3111213
Results 121 to 127 of 127
Thread: Testarossa replica build
  1. #121
    154
    Quarter window work
    OK, now that I am getting ready to start panel to panel bodywork first things first. I have to modify the opening and install the quarter glass. Originally they were merely glued in with no structure under them to support the weight of the glass. I shaped the opening so that the glass sits flush, and will be building a metal frame and window channel underneath the window opening. The reason I am doing this now is because in order to get to this area I had to unbolt the quarter panels. I need to do this first and then realign the rear panels then do finish bodywork. Here she is all opened up for surgery.
  2. #122
    154
    Quarter glass frame work.
    So i got some time on Sat to build my quarter glass frame work with incorporated lower window channel. This will support the glass and will make it to where the glass and the frame can be trimmed out really nice. I still have to add a small amount of metal to the top window opening section. also the glass will sit up higher, it will have a rubber mount bushing to dampen the friction of movement. Once all adjustments are made this will get welded in. I basically made my template from cardboard, transferred that to metal, cut it out with my jigsaw and used my stop brake to make the required bends.
  3. #123
    154
  4. #124
    1,433
    Nicely done. But then again, all of the work you have been doing has been really top notch. Well done. Keep the updates coming. I for one am truly enjoying the progress.
  5. #125
    Senior Member Jbrown's Avatar
    Jan 2003
    219
    Love how your engine cover is seperate from the engine cover.. mine is all 1 piece..
  6. #126
    319
    Absolute craftsman! Love the documentation you share here, as well.
  7. #127
    443
    Its coming along sweet !, -Vinny
