Thread: nut inserts
    nut inserts
    Hopping someone has some sources as I had run out and none of my suppliers don't have it and cant find it anywhere on the net.
    I'm looking for a nut inserts shaped lite a T flange on one side and narrow knurled skirt all the way through that I can put into a 3/8 aluminum plate. The nut needs to be fully threaded 3/8 in length with 3/8-24 thread.
    All I can find are either collapsible that are inserted with tool and squeezed or longer ones that are only threaded half way.
    I cant attach any pictures as example (erh) and I can do is post a link http://mychimaera.com\imgs\nut-insert.jpg
    any help is appreciated
    Nov 2005
    1,119
    I couldn't get your link to load. The only kind I use is with the setting tool but if I could get the link to work I can look around. Fine threads in aluminum insert might be harder to find. I looked at what is available in the brand I use with the setting tool and they are 3/8-16.
    Bart
    http://www.jhpfasteners.com/half-bli...4003-l-en.html
    Also check Amazon. They have tons on there. I order from them almost weekly.
    First off thanks to both of you for the replies
    Bart,
    I may have explained it incorrectly never the less I think you are referring to "crush" type inserts that are fastened with a tool then shoulder gets compressed in order to fasten it
    Flyhilandsoft,
    This is exactly what I'm looking for and thank you for the link. I had never thought of Amazon as a hardware supplier. I'll check to see if they have other options.
    Again thanks to both of you
    Nov 2005
    1,119
    If I need to install 1/4-20 or smaller. I have one of these and they are available from the local Harbor Freight or online.(http://www.harborfreight.com/45-piec...-kit-1210.html) I have a higher end brand name, can't remember but seems like Arrow. Anyway it got legs and walked off. I replaced it with this cheap Harbor Freight one and I've had it 5-6 years. Works fine.
    For larger ones I use ones I got from Grainger (https://www.grainger.com/category/nu...gestConfigId=6) You'll have to search for your size. I have this setting tool for 3/8 and I notice it has 3/8-24 but I use 3/8-16 (https://www.grainger.com/product/GRAINGER-APPROVED-Hand-Tool-32FY25?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/32FY21_AS01?$smthumb$)
