Thread: Automatic transaxel problems
    Jul 2012
    7
    Hello everyone!
    I had plans to use a ZF 5hp19 (from a fwd Audi) to my Lamborghini projects, but now th PCS no longer support the box.
    Do you know any other company that sells aftermarket computer boxes to electronic automatic transmissions? Or do you know of any other trans-axis (longitude assembly) capable 300hp 450Nm? I want to remember that anyone here has mounted engine and gearbox back to front and a V-drive back to a rear axle, will anyone remember?
    Grateful for answers
    May 2006
    201
    Double A here you go was done by KevKev60 and it worked http://www.kitcentral.com/index.php?...view_album.php
    also can you give any more details about pcs cause i have a mate doing an Aventador with that box combo, it would be good to let him know some detail.
    Jul 2012
    7
    Hello Lambolex.
    PCS had a Box (TCM-2000) that worked with 5hp19 but it is replaced with TCM-2800 and does not support 5hp19.
    Thanks for the link, I'll check it. What is your opinion, will the engine mounted too high?
    https://www.powertraincontrolsolutio...on_Controller/
    May 2006
    201
    Hi double A here's a link to a local outfit in nz that says they support a 5hp19 it could be worth a follow up http://www.nzefi.com/product/auto-tr...-pcs-tcm-2000/ as far as the height it's unknown from here depends what motor and clearence to engine cover the position from front to rear and the height of the intake along with height of transaxel drive flange it's really a big guess till you have the components to move around
    Jul 2012
    7
    Lambolex Thanks for the information, I have checked KevKev installation and I really like the layup. I have a BMW V12 and I are considering a GM 4L60E (easy to find the control box). I have emailed Casale to check out what they have to offer.
    Senior Member AdrianBurton's Avatar
    Jun 2003
    Charlotte, NC
    915
    or Leon of beyond customs in Australia
    Jul 2012
    7
    Adrian, do you have more information about Leon?
    Jul 2012
    7
    I have found beyond customs, thank you so much for the tip. Seem very interesting.
    Jun 2003
    Charlotte, NC
    915
    He is a great guy, and you will see
    tell him that I sent you
