Thread: Countach parts list, real and replica.
    Aug 2013
    795
    parts list for Countach
    *Prices subject to revision (up and down!)
    Most parts available/seven days (couple works in progress)
    1. Euro style front bumper grilles. Aluminium, powder coated with stainless fittings and correct bases. $199 per pair.
    2. Carello front amber/clear turn signal lenses. $99 per pair.
    3. Rodney Dickman front turn signal housings supplied at cost. $89.95 pair. Powder coated black/clear $129.95 per pair.
    4. Front turn signal bucket covers/lenses. Lexan, correctly mechanically engraved with manufacturers mark. Left oversize to allow cut to shape or supplied OEM size/shape. $225/250 per pair
    5. Metal turn signal buckets with correct tabs and mountings. Powder coated silver. $450 per pair
    6. Front turn signal bucket/lens frames from Udo Keul. $160 pair powder coated black.
    7. Front Euro Carello 444 foglamps, white/yellow. $TBA
    8. Ashtrays, correct, refurbished. $199 each.
    9. LP400 centre forward switch panel. Powder coated and screen printed $199 each.
    10. Round vents to suit (3D printed) $99 pair
    11. Switches/switch buckets to suit $TBA
    12. Red/Orange lights to suit $25 each
    13. LP400 side warning light panel $99
    14. Large (OEM size) brake switch $99 (recon), thin brake switch $25 (new)
    15. Warning light buckets to suit $15 each (red lenses)
    16. LP500/5000/S centre forward switch panel (for two sliders). Powder coated. $199 each.
    17. ‘HEAT’/’DEF’ sliders with knobs $150 pair
    18. Various square switches $100/150
    19. Cigarette lighter, various lamps, switches, rotary controls. $TBA
    20. ‘Small’ (correct) vents to suit $99 per pair
    21. QV centre forward switch panel (for one slider) Powder coated $199 each.
    22. Cigarette lighter, various lamps, rotary controls. $TBA
    23. ‘HEAT’/’DEF’ sliders with knobs $75 each
    24. Switches to suit $100 each.(Hazard, fan & light switch)
    25. Replica (rear) fog light and position light switches $150 each.
    26. Correct vents to suit $99 per pair.
    27. Replica gear shift knob with medallion. 1 piece $100 each, 3 piece, $240 each
    28. Correct window winders with chrome strip $79 per pair
    29. Shift gate from Udo Keul at cost with lockout $150 each
    30. Exact resin copy of steering column shrouds (upper and lower) $499 per set.
    31. Gauge panel in aluminium for QV or 5000S $199 each
    32. 6 piece door glass set. Tempered, tinted, OEM size and compound curved $TBA (We think this is close now. :-) )
    33. Curved, tinted, tempered rear quarter windows $TBA
    34. Flat rear window $TBA
    35. Curved tinted, shade band laminated OEM sized windshields $TBA
    36. ‘LAMBORGHINI’ rear badge, stainless, threaded studs, powder coated, choice of colours $75 each
    37. ‘COUNTACH’ rear badge, stainless, threaded studs, powder coated, choice of colours $75 each
    38. ‘BULL’ rear badge, black resin. $50 each
    39. ‘5000Quattrovalvole’ stainless, threaded studs, powder coated, choice of colours $50 (also have stick-on aluminium versions of the script badges)
    40. Various data plates from Lasse Lund $TBA
    41. Red acrylic tail light frames with correct Carello reflectors $250 (LP400S/500/5000S/QV) [drilled and tapped with threaded studs/nyloc nuts +$25]
    42. Red acrylic tail light frames LP400 $199 [drilled and tapped with correct threaded studs/nyloc nuts +$25]
    43. Correct square pattern metal tail light mounting frames, with backing plates, $150 per pair.
    44. Inner exhaust tips/exhaust shields in the making.
    45. Most other Countach parts sourced/supplied…
    K9COP
    Please message me with question or picture needs. Thanks for looking. Picture here, and more in this album:.
    http://<a href="http://s37.photobucket.com/user/pauldewing/media/Project%20Countach/Parts%20pictures%20December%202017/Parts%203ab_zpseuz7bfcg.jpg.html" target="_blank"><img src="http://i37.photobucket.com/albums/e77/pauldewing/Project%20Countach/Parts%20pictures%20December%202017/Parts%203ab_zpseuz7bfcg.jpg" border="0" alt=" photo Parts 3ab_zpseuz7bfcg.jpg"/></a>
    Aug 2013
    795
    Argh, still can't work out this site for pictures or links.
    May 2017
    Can't get site to work either.
    19
    Guys,
    just purcahsed an LP400 centre forward switch panel from Paul and must say it is superb quality!
    I highly recommend this seller!
    Luke
