Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Glassing Foam
  1. #11
    Hi guys,
    Thanks for all the suggestions.
    I have kinda solved the problem.
    I coated 3 layers of fillers and sprayed primer and painted. the extra coating works.
    I will also try this product called ENVIRO TEX Lite
  2. #12
    never tried latex paint but its claimed to work perfectly, I personally use automotive (oil) type primers but I topcoat the foam first with plaster. Be careful on larger areas especially flat or ones with small curves. if you are putting just a very thin layer of filler heat from curing resin will melt the foam and distort your molds or parts if you just interested in parts.
