Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 186
Thread: Modern-day Miura
  1. #151
    259
    Post Disc Brakes
    In parallel with modeling the station buck, Iíve started working on the brake system. Iíve elected to go with an aftermarket brake system made by Wilwood. Itís a high-performance brake system utilizing 13Ē rotors on all 4 wheels, 6 piston calipers, and a pedal assembly with built-in balance bar for front to rear bias adjustment on the fly. I ordered up all the pieces a while ago and now am beginning the initial assembly process.
    While going aftermarket on a brake system gives a lot of flexibility, it also can make for some engineering challenges as this collection of parts didnít come off an assembly line in an auto plant. The first challenge I ran into is with mounting the calipers to the suspension uprights. The calipers were designed to be mounted with two 3/8Ē bolts and have only 9/16Ē between caliper mounting tabs and rotor for fastening. The suspension uprights are aluminum and given the limited space available, I canít use traditional fasteners like hex nuts behind the aluminum upright. The two milled off areas on the upright is the caliper to upright mating surface.
    I could have drilled and tapped threads into the aluminum upright but I donít like this especially for a critical safety item like brakes that will be constantly going through heat/cooling cycles. The 2 fastener options I came up with are heli-coil inserts or a tee-nut. While a heli-coil would give the bolt threads something other than aluminum to grip, the heli-coil itself would still be threading into the aluminum. So better from a standpoint of serviceability in tightening/removing caliper bolts a repeated number of times but still not so good related to grip strength of threads in the aluminum.
    A tee-nut gets its name because it looks like a ďTĒ in side profile. The most common use of tee-nuts is in wood where thread grip strength might be an issue and the associated fastener is typically a medium sized screw. I couldnít find a source to buy tee-nuts with a 3/8Ē bolt thread so Iíd need to machine them myself. While it would take quite a bit of time to machine tee-nuts, I felt it was worth it to end up with a superior end result for worry free brakes. A tee-nut would give me about ĹĒ length of thread in steel and a solid flange type head to sandwich the aluminum upright to the caliper.
    I started with partially threaded ĹĒ stainless steel bolts. I used a lathe to drill holes into the center of the bolt head and down the shaft. The drilled hole was then threaded for 3/8Ē-24 threads using a hand tap. I then used a vertical mill to machine the bolt heads down to 1/8Ē thick so they would clear the rotor. The bolt shaft was cut off with a hack-saw and remaining shaft ground to final length on a grinding wheel. The picture above shows at various stages of machining where rearmost one is completed tee-nut with a 3/8" bolt in it. Like I said lots of machining and time to make each one and 8 tee-nuts were needed.
    The rest of the assembly on the car was straight forward. I double checked the clearance and have about .030Ē between the tee-nut head and rotor surface. Not a lot but it should be enough. This brake system uses a separate cable operated caliper for parking brake. Thatís the smaller caliper in front.
    More to come on brake systemÖ
  2. #152
    208
    your doing incredible work. I love seeing the progress.
  3. #153
    27
    This is an amazing build!
  4. #154
    259
    Quote Originally Posted by bodyman View Post
    Quote Originally Posted by luke.jenner View Post
    Thanks guys!!
    This may sound funny, but I'm really having fun with the project as well. And I haven't even gotten to the part that prompted me to take the project on yet, metal shaping the bodywork.
  5. #155
    259
    Post Radiator coolant tubes
    Iíve switched focus again from brake system to coolant lines. A great thing about a project at this early stage is that if you hit an issue with one area, thereís plenty of other areas where progress can be made. Iíve decided to connect the radiator openings to the main under chassis coolant tubes with 1 ĹĒ purpose routed, bent aluminum tubes. I am making these from mandrel bent Al 6061 tube and welding them together. I did some preliminary design and ordered up the mandrel bends and silicon hose adapters/couplers I thought were needed.
    I started fabrication with the bottom tube as I needed to establish its position so the upper tube could be routed around it. Both these tubes need to be routed to clear the spare tire.
    One each of 120 degree, 45 degree and 60 degree bends and 2 welds were needed to complete this tube. All in all, fairly straight forward. The upper tube is more complicated as it needs to be routed over the rack & pinion but still under the spare tire. A 180 degree bend cut in the middle and repositioned gives the needed jog for this. A hose clamp temporarily holds the joint for mockup purposes.
    I then started from the other end to determine what type of bend was needed for the middle. For the middle tube area, I need a bend thatís between 15 to 20 degrees. Of course, I donít have one of these and it took an Internet search to find a source. I found a source for an 18 degree bend and now have it on order.
    I need to have an air bleed valve at the topmost part above the radiator so I made a bung and welded it on at the top of the top tube.
    Iím now at a hold state to finish these coolant tubes until the last tube bend arrives.
  6. #156
    259
    Post Radiator coolant tubes (cont.)
    I finished fabricating and welding up the front cooling tubes.
    A final check to ensure these will clear the spare tire. Thereís still an inch to spare
  7. #157
    259
    Post Front clip station buck
    Iíve been focusing all my garage time over the last few months on the C5 GTO. The GTO is now getting to the stage that Iím dependant on others to do some work for me, so Iím able to context switch back to the Miura project.
    I finally got a chance to assemble the station buck for the Miura front clip. As you might guess, it's like trying to assemble a big jigsaw puzzle with an extra challenge. The pieces all have an air gap in between them. After some trial and error, it came together and looks great.
    The CAD model that resulted from the design step for the station buck:
    The CAD model for the front clip of station buck:
    Hereís what it looked like when coming home from getting ĹĒ Baltic birch plywood cut on CNC router:
    Finally, with all the front clip stations joined together in place.
    The missing areas like grill, headlight, and vent openings are where hammer forms will go. I'm still working to get the hammer forms shaped/cut on CNC router.
    What I like about it:
    ∑ It's free standing with it's own legs
    ∑ It's lightweight enough that I can slide it around the shop
    ∑ All station intersections easily aligned
    In addition, I'm really impressed with the accuracy of going from a CAD model to CNC instructions to cut 1/2" plywood stations. The slots are tight enough to hold stations firmly in place. I used a rubber mallet to tap interlocking stations in place and then a wood screw through the intersections to keep them there.
  8. #158
    856
    Joel, if I have not said it before, I am very proud that you selected one of my chassis for this project. Incredible work.
  9. #159
    259
    Charley: I have no regrets for choosing your chassis for this project. I just hope that the resulting car will live up to all the great design innovations that are embodied in your chassis. You've set a very high bar
  10. #160
    259
    Post Mounting Miura Pedal Assembly
    While the Ferrari GTO was out getting the headliner installed, I had the chance to work on the Miura a bit. I had purchased the brake/throttle pedal assembly prior and now I wanted to get it mounted in the chassis. I had first gone down the path of using a pedal assembly where the pedals hang down and master cylinders are mounted up top. I found the clearances were just too tight with the cowl and steering column to make it work as I wanted it too.
    So I switched directions to using a floor mounted pedal assembly that uses master cylinders with remote reservoirs. This way, I could make the pedal assembly adjustable for tall people like me or for people with normal length legs. The remote reservoirs are needed as the master cylinders are located below the plane of the brake calipers and the reservoirs need to be placed above the plane of the calipers to prevent unwanted fluid drain back.
    I mounted the pedal assembly to a ľĒ thick aluminum plate. For adjustment, a series of holes spaced ĺĒ apart were drilled in the plate. The pedals now have 3 ľĒ of adjustment by unfastening, moving, and re-fastening the 4 bolts that secure the plate.
    Pedal assembly as viewed from above.
    As viewed from driverís seat.
    As advertised by Charley Stickland, his chassis does have lots of leg room. With the pedals now mounted in place, my long legged, 6í5Ē body fits well with plenty of legroom!
