Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: suspension
  1. #11
    1,343
    Quote Originally Posted by jb1 View Post
    Plan is longitude setup in both cars.. which will make suspension swap a bit easier than attempting with transverse setup.. I have 3 other fieros besides these 2 kits.. I'll drive them if want fiero handling ..Lol..
    Im not sure the c5/c6 setup is best choice but from looking them over seems to be the simplest upgrade..
    Very cool. Please keep us updated on the progress. I'd like to see how you do it. If nothing else, the C5/C6 setup should be readily available. I've looked at the C4 hardware in my local salvage yard (they had 3), but right now it's a pipe dream.
    Good luck and keep us posted.
  2. #12
    From what I am seeing locally , the whole assembly runs around $500... I will at least attempt it... I was reading an article about using the Lexus axles as the inner fits the Porsche trans and the outer joint fits the c6 bearing assembly..
    Trying to keep everything in budget.. I know times your better off spending the money... And if it is crucial there is no problem spending for it to be right.. but I will research and exhaust other avenues..lol
  3. #13
    844
    JB1, I researched and wrote that article about the axles and you are right, they fit the C6 hub. That is the good news, the axles are under $100 each instead of custom $1,000-$2,000 axles from Summers or TDS. The bad news, I am not sure what you mean by the whole assembly, but four C6 hubs alone are going to be $500.
  4. #14
    180
    I've had great success with buying junkyard axles from any car where the axle rods are the correct OD and longer than needed. I then discard the CV and tripot joints from either end, and have a machine shop shorten and re-spline the ends to fit my own joints. With a bit of research, you can usually find an axle rod that has the correct splines on at least one end. That reduces the cost since once shortened, only one end needs to be re-splined. Typical cost is $50 per used junkyard axle, plus about $75 machining for two ends.
  5. #15
    76mx no the whole rear cradle assembly with control arms axles shocks and all , on eBay and locally runs around $500
    That's a good article you wrote with lots of good information. I have since lost the link to it... Hopefully you are able to post that link up again for myself and others
    *Edited .. I tried posting link to c6 rear suspension on eBay doesn't complete link..... $509 free shipping.. multiple listings and even on car-part.com around the same price in my area..
  6. #16
    844
    JB1, thank you. There is an article I wrote for Carbuilder magazine that is still available online in their archives but it deals only with the C5 stuff. The more up to date information on the C6 stuff is in my Youtube video #28 at StricklandRacingInc.
  7. #17
    Thank you 76mx , subscribed.. I been a member here for near 20 years, always been extremely intelligent helpful people here... Even though this sight has gotten a lot slower than it was in its hayday still a lot of great people here..
  8. #18
    454
    Hello jb1 , Charlie76MX, Joel and Blooze with others here are a great help with the knowledge they openly share. I read your question and thought I could add to the discussion. I have a 512 kit on a stretched fiero here, along with another longitudinal build going that uses all C5 rear suspension, brakes and stock C5 axles. My solution to mate the C5 stuff to the Boxster 5-speed was to use Porsche 930 inner CV's (the axle spline matches the C5) and a pair of 100mm to 108mm pattern adapters at the output flanges. My 97-01 Boxster trans from a 2.7 car has the small 100mm pattern flanges. I considered putting the C5 set up in the rear of the 512TR, so I measured the width of this set-up and would need 4'' longer bare axle shafts on both sides to fit the TR body's wider rear stance, the CV's would not be affected. BTW the porsche 930 CV is a plunger type which helps everything play 'nice'. jbi , why not use C5 stuff ? -Vinny
