Thread: Closed Cell Foam for Dash / Door Panel Project
    Hi Everyone,
    Can someone give me an idea of the best closed cell foam (or preferred) to use for a custom door panel / dash / console-sides project I'm working on? I know that it seems Ken / WraithInnovation (off the top of my head) as well as others seem to have quite a bit of knowledge with these things.
    In the past, I've used EVA (Ethylene Vinyl Acetate) and a Cross-Linked Polyethylene and I think one other type.* It's been so long I can't remember which would be a better choice.*Or if there is anyting "new and exciting to use".* I've been looking at this* Volara closed cell foam as well recently.
    I have some scraps from before and it looks like I used 1/8" for the door panels in the past and for the sides of a console (and then covered both with vinyl).* This is what I can't remember:
    1. What type of glue I used.* I think I used PVC glue with the EVA (I think).* Can anyone help?
    2. do you think 1/8" foam for the dash is do thin ?* I keep thinking I should use 1/4".* The vinyl (with the U.V. Inhibhitors of course) does "squash it down" pretty good but I don't want it too "thick looking".
    Any tips on this would be a great help. I'm leaning toward the 1/4".
    Previous Builds: AF - 308 Replica w/ V8 & GM F-body Testarossa Replica
    Current Toys: 308 V8 Project #2, 91 V-12 Jaguar XJ-S Coupe. 1983 Hurst\Olds, 1979 Trans/AM - 468CID Bracket Car.
    Aug 2003
    1,103
    Re: Closed Cell Foam for Dash / Door Panel Project
    I am using 1/8" 'black closed cell' on the dash and 1/4" 'white closed cell' on the flats of the door panels.. on the contoured parts of the door panels i'm using the 1/8" Console will get 1/4" I use a product called Tack-It its a high-temp spray adhesive that works very well. Using pad this thin be sure to have a perfect or close to perfect surface to start with.. Do all bodywork because any flaw will show thru. good luck!
    Just smart enough to be very Dangerous
    I agree,
    With that thickness of Closed Cell Foam, I would imagine that every little imperfection would show right through.
  1. F355 interior door panel to dash gap
    By Brastic in forum Technical Discussion & Question
    Last Post: 08-25-2009, 01:49 AM
  2. lambo door panel
    By fastlap36 in forum Technical Discussion & Question
    Last Post: 04-09-2004, 07:29 AM
  3. Outer door panel removal, for the nubes.
    By James_Bond_007 in forum Technical Discussion & Question
    Last Post: 03-12-2004, 05:52 PM
  4. Seperating door rocker panel
    By fly355 in forum Technical Discussion & Question
    Last Post: 10-31-2003, 12:10 PM
  5. Has any1 ever sperated the rocker panel from the door?
    By KillerX in forum Technical Discussion & Question
    Last Post: 07-03-2003, 08:07 PM
