Page 120 of 123 FirstFirst ... 2070110118119120121122 ... LastLast
Results 1,191 to 1,200 of 1222
Thread: Ferrari 288 GTO - BUILD - Project
  1. #1191
    3,056
    Quote Originally Posted by Don View Post
    And this si what the ECM opening should look like. Graeme, 85-308, has graciously offered up his ECM for the build so I am just waiting to hear back from Sinister Performance and what he requires to be sent to him for the flash.....
    Ha ha ha - Congrats Don. If you pulled all your hair out in the process, don't worry, It will grow back soon! Hope to hear it run soon.
  2. #1192
    3,485
    Sean;
    Sadly the problem is at my age as the hair comes out it doesn't necessarily come back anymore.....
    So, ECM on its way here thanks to the generosity of Graeme (85-308). The updated chip ordered from Ryan at Sinister Performance. I have to wire in the 3 wire high pressure A/C sensor so will do that and then I can move back into the interior and do the final updates on that area while waiting for the stuff for the engine to arrive.
    Forward progress finally.
    Wonder what I am going to find next........
  3. #1193
    3,056
    It happens to all of us Don. I had a unfortunate event some months ago with Funnywheels. I got on it a bit to hard and one of the CVs pulled out of it's socket. Come to find out later that the Fiero trans mounts bent and caused the motor to shift enough to change the distance from the wheel hub to the trans. I wasn't smart enough to realize that that was why the CV failed. So, after replacing the CV parts (which wasn't easy because Dave had them custom made and I didn't know what car they came from) It failed again just pulling out of the driveway. After closer inspection I realized the mounts were bent so I ordered all new heavy duty ones from Rodney Dickman. 2 weeks later I got it all back together again and all was good. The following weekend I went up in my attic looking for something and low and behold, I came across another set of Rodney's Trans mounts sitting in a box I never used. Oh well, now I have replacements that I will probably forget that I have...…………. again
  4. #1194
    3,485
    While I wait for parts to arrive again, I am focusing on a couple other areas that I wanted to look at. I wanted to redo the centre console carbon fibre as it just didn't turn out that well when I did it a couple years ago,. Wayne, dobie1, has a vacuum bag setup and has been pulling parts for a while now so good at it. I built up a bracing system so when we vacuum bag it, it will have a lot less ability to warp on us. I also want to have the 3.4 head cover to be carbon fibre and then I will put a Ferrari script on it. I ground the 3.4 DOHC off it (which was pointing in the wrong way anyway, and then filled in the spots to give a good surface. We are going to vacuum bag this one as well but will need to do a lot less vacuum as this one is not as well braced by the nature of its construction. Tape is on it in these pics until the caulking is dried. I used caulking to secure it to the frame and will be a lot easier to pull off afterward.
  5. #1195
    3,485
    First part in carbon. An amazing improvement on to what I had done previously.....
    We are talking about maybe putting the Ferrari emblem script against the cover and then vacuum over the script as well to give it all a carbon shape. Not sure the cover will survive the vacuum without warping or getting misshaped if we have to go that hard on vacuum to pull out the edges of the script.... Might try a test run ... I am going to 3d print the Ferrari script so we have a disposable mold for the script.
  6. #1196
    489
    Looking good Don, do the original parts remain and go back on the engine ? Like wrapping a part .
    or just the new carbon fiber top layer is now the part? I’ve seen videos of vacuum bagging in which the resin is pulled into the bag to thoroughly encapsulate the part , then the part is removed off the mold shape . Was this the way it was done ? Any pics of the process ? It really looks trick . Thanks, Vin
  7. #1197
    3,485
    Yes. This is only a cf covering layer to the thicker part underneath on my application. We have also done the "make a mold and then vacuum a cf part from it" as well so that you start with a fresh standalone part but these parts are only coverings. The engine cover has mounts under the top lid that connect to the fuel rail that I did not feel like having to remake etc.....
    I also received my parts from Graeme so I now have an oem chip to go into the ECM and spare ECM and the flashed part from Sinister Performance is in transit to me.
    Progress
  8. #1198
    Feb 2020
    13
    Wow, I saw this car being built on Pennock's. I would love to have this car with an IMSA Fiero body attached to it. What a work of art. I say you should kick the rear wheels back 2-2/4 inches and mount your 355 on it with a roof. That would make a statement.
    If you want to resell it, I am interested!
  9. #1199
    3,485
    Still waiting for the update chip so continuing to address additional items.
    I thought I would pull the 3d printer out and tryout some ideas for the Ferrari logo on the engine cover. I asked Wayne to vacuum bag my engine cover and he did that at the same time he did the centre console for me. Turned out well and just need to do a bit more cleanup and probably another coat of resin to get rid of the last imperfections in the surface. While doing that, thought I would see if a 3d printed logo would work.
    Not sure the depth of the lettering is correct yet as it is 5mm and pretty tall.... I plan to finish cleaning up the lettering and paint it the same colour as the engine and car and should stand out on the carbon fibre once it is also cleared again.
    Thoughts and feedback on the height, depth and size of the lettering?
  10. #1200
    3,485
    I am also doing a PC Board that will work with an Arduino that runs the HVAC in the Fiero project for Wayne and connect directly into the stock HVAC wiring plug. Similar to what Riceburner did back in the day but I am using a full Arduino rather than his work to use only the atmel 328 chip (same chip that runs the Arduino).
    It is getting very crowded on this board so may need to revisit wire tracks and placement to make it better overall but to get it up and running and tested this way first as I was learning the software and process at the same time....
  1. A Little Project I am Working On BUILD
    By slipondajimmy in forum Build Diaries
    Last Post: 03-07-2012, 03:26 PM
  2. 512TR BUILD Project
    By bodyman in forum Build Diaries
    Last Post: 10-12-2011, 02:57 PM
  3. help needed for design and build project
    By rossicars in forum General Kitcar Chat
    Last Post: 10-26-2006, 05:48 PM
  4. What to build next? Or whats your next dream project?
    By StormBringer in forum General Kitcar Chat
    Last Post: 04-25-2005, 01:26 AM
  5. Project build site available
    By racing_trends in forum General Kitcar Chat
    Last Post: 12-02-2002, 01:18 PM
