Thread: working with fiberglass
    Jul 2004
    386
    how do you layup fiberglass without getting the gatoring affect?
    3,395
    Re: working with fiberglass
    If gatoring you mean bumps(uneven) surface on the finished glass, there are a couple ways.
    If you need a flat panel, take a mirror or a sheet of glass and lay up the fiberglass on that. When taken off the glass, the fiberglass will be very smooth on that side.
    If you are layering mat over panels to cover holes or build up parts, there really isn't a way to easily get rid of the bumps in the glass completely. When laying up the glass, the best you can do is get a fiberglass wheel that you roll over the paid up areas and it pulls resin to the surface. This reduces the bumps but never gets rid of them all together.
    The way to get perfectly smooth glass panels is to build up your buck of the part you are making, lay on tooling gelcoat and then layers of glass to make a mold. Take the mold off the part and lay up your final part in the mold. Depending on how much work you put into the buck and mold will determine how smooth and clwean your final part comes out.
    If you are referring to bumps in the gel coat that was laid out before laying up the fiberglass layers, I found that you need toi really allow the gel coat to cure well and then sand it well if you have used waxed gelcoat before laying up the fiberglass on it. Separating between the glass layers usually means either incomplete mixing of the resin before using on the mat/cloth or impurities(dirt, grease, water) in the mat/cloth when layingit up.
    A long answer to what I hope was your question.
    I've tossed this idea around for a while, but was concerned that it would cause the glass to get too hot and crack. Any troubles with that?
    Moderator FunnyWheels's Avatar
    Nov 2002
    Tampa, FL
    8,151
    Quote Originally Posted by RHK
    There are several options I have personally used. The easiest was the rear Fiero glass to build small parts, wheel wels etc. The other was to use a glass sliding patio door. You just use mold release like you would on anything else. If you are mixing your resin to produce as much heat as needed to explode glass, you might be cooking your mix and need to use less hardner. It should take 20 min to an hour to properly cure (tack up).
    Dave
    Attached Images Attached Images
    If you're not confused, you're not paying attention.
    3,395
    I use a long mirror left over from anold renovation. It is about 1 foot wide and around 5 fet long.
    No problems with heating and cracking at all in what I have done.
    Jul 2004
    386
    after gel coating and curing for 24hrs I then layup the fiberglass and the gelcoat wrinkles like an aligator
    Jack
    What kind of temperature and humidity conditions are you performing your work in?
    I think something might not be curing properly.
    Jul 2004
    386
    low humidity about 70 degrees.
    Well that's about the perfect conditions, so that shouldn't be it.
    How about mixture? If everything isn't mixed completely, you'll have over-catalyzed and under-catalyzed spots, resulting in uneven curing.
    Obviously I'm just offering conjecture since I'm not there to see it. Can you post a picture of what you're getting?
  1. How Well Does New Fiberglass Bond To Already Cured Fiberglass?
    By mlochala in forum Technical Discussion & Question
    Last Post: 08-24-2011, 09:50 PM
  2. Anybody working on R8 Replica?
    By pauldays in forum The Mall
    Last Post: 04-21-2011, 01:50 PM
  3. working with fiberglass...
    By jntramey in forum Off-Topic
    Last Post: 07-23-2010, 07:02 PM
  4. Working with Fiberglass
    By Sofa King in forum Technical Discussion & Question
    Last Post: 10-05-2007, 05:55 PM
  5. working on 360 replica
    By stefan2002 in forum General Kitcar Chat
    Last Post: 01-09-2003, 05:28 AM
