Thread: rubber strips between fiberglass panels
    I was wondering about placing rubber strips between fiber glass panels to help stop rattles. Has anyone done this before?
    Dec 2002
    New England
    1,637
    Re: rubber strips between fiberglass panels
    I am curious as to which two fiberglass panels are rubbing together?
    On my AD355, the front and rear bumpers are bolted to the fender and rear clip. Fiberglass to fiberglass. I am not worried about the deck lid or hood because I am using rubber hood spacers.
    I used 1/8" thick by 3/4" wide foam tape between my upper hood scoops and my body. They add a bit of definition to the parts, help stop squeaking/rattling, and stop the little vibrations from eating into the parts:
    I guess you can't really see the foam in this picture, but its cool, nonetheless... ;D
    Meddle not with the affairs of the Dragon, for you are crunchy... and taste good with ketchup.<br />http://www.rc-sub.com/resources/grap...ni/avatar2.jpg
    Moderator FunnyWheels's Avatar
    Nov 2002
    Tampa, FL
    8,151
    foam tape will work the best.
    If you're not confused, you're not paying attention.
  1. Which rubber for weather stripping
    By N.H in forum Technical Discussion & Question
    Last Post: 03-18-2011, 05:32 PM
  2. Question about fiberglass panels (how much to use for a panel)
    By blackpass in forum Technical Discussion & Question
    Last Post: 01-12-2011, 10:11 AM
  3. Fiberglass panels Illegal in Australia?????????????
    By ll210 in forum Technical Discussion & Question
    Last Post: 09-15-2009, 10:15 AM
  4. Repairing Rubber Panels ?
    By SpecialEffectsGuy in forum Technical Discussion & Question
    Last Post: 08-27-2006, 02:01 PM
  5. will this work for fiberglass panels?
    By 308fiero in forum Technical Discussion & Question
    Last Post: 09-12-2004, 09:14 PM
