Mad Mechanics - Custom and Kit Cars Forum Visit our friends!
Kit Cars Links
September 10, 2010, 05:40:38 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: No News is good news!
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: Audi 5000 trans speedometer  (Read 367 times)
496fe
Full Member
Offline Offline
View Profile
« on: February 22, 2010, 11:15:06 AM »
What are all you guys with Audi transaxles using for speedometers?
Logged
migwell
Full Member
Offline Offline
View Profile
« Reply #1 on: February 22, 2010, 11:42:06 AM »
Im using the VDO clocks which run from magnets on the driveshafts, these will work on any transaxle , and are easy to programme
Logged
 Logged
496fe
Full Member
Offline Offline
View Profile
« Reply #2 on: February 22, 2010, 07:00:44 PM »
Do you have a part number or a more complete description?
Logged
jdinner
Patron Class Member
Hero Member
Offline Offline
I'm feeling older
View Profile WWW
« Reply #3 on: February 24, 2010, 04:09:53 AM »
I made a small bracket and mounted a GM ABS sensor close to the heads of the axle bolt heads, inboard.
This gives me six pulses per axle revolution. Since the VDO head unit is programmable I can fine tune the head to be perfect.
The sensor was one that came with the S-10 wheel bearing I used on the rear drive. The bearing is from a 2001 S-10 pick up 4X4 Front Bearing.
Logged
migwell
Full Member
Offline Offline
View Profile
« Reply #4 on: February 24, 2010, 04:22:40 AM »
The speedo pick up I use with VDO clocks is from Demon Tweeks, can get the part number if you need it.
Just make a small bracket to hold the pick up which will sit close to the magnets, mine was just a small strip of metal screwed to the gearbox, then you bond either 3 or 4 magnets supplied in the kit to the driveshaft,(mine has 4 magnets bonded to the 1st part of the shaft coming out of the gearbox)
(I would suggest using shielded wire from the pickup as I found mine was picking up other magnetic pulses from my wiring loom and giving false readings)
once wired up,  Its so easy to program, and there are various ways of doing this, I just drove mine on the motorway with satnav and set the current speed, past the vehicle inspection no problem.
Logged
496fe
Full Member
Offline Offline
View Profile
« Reply #5 on: February 24, 2010, 08:31:44 AM »
Thanks for the tips.  I am using Corvette C4 hubs on the rear.  They already come with ABS sensors that "point" at a cogged wheel with what looks like about 60 "teeth".
1) Are these "teeth" magnets?
2) Does this sensor provide the correct signal for the VDO?
3) Is the VDO capable of being programmed for this many teeth?  If not, could I knock some of the teeth out and end up with 4 or 6 and make it work?
You guys are providing a great service because the Audi/Corvette combo seems to be getting popular.
Brian
Logged
Mbdiablovt
Jr. Member
Offline Offline
View Profile
« Reply #6 on: February 24, 2010, 08:41:15 AM »
I don think that knocking teeth out would be a good idea. You could try these http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=109/category_id=311/home_id=59/mode=prod/prd109.htm
Jim said the gauge is programable and his way is a prooven method
I know these work with the Audi 5000 trans. I have to use one to get the V12 engine management i bought from tony @ choice auto wire to work and it connects directly to the trans w/ a slight modification
Logged
jdinner
Patron Class Member
Hero Member
Offline Offline
I'm feeling older
View Profile WWW
« Reply #7 on: February 24, 2010, 06:47:57 PM »
I tried to set it up with the ABS hub and sensor. It was reading 300MPH with a Snap-On scanner. It has far too many teeth on the ABS wheel. This is why I pointed it towards the axle bolts. No, the teeth are not magnets. Think of the sensor as a magnet on a spring, when it is close to metal it closes the circuit.
http://www.egauges.com/pdf/vdo/0-515-012-051.pdf
Look at connection #2 on page 2. This is how to wire it.
Logged
chimaera
Patron Class Member
Full Member
Offline Offline
View Profile WWW
« Reply #8 on: February 24, 2010, 07:19:22 PM »
I'm not sure abou the 016   (Audi 5000) trans, but my 012 and couple others that I had seen already have speedo signal ouing out from them and they are generaly .52 in ratio.
Stupid question but why reinvent the wheel if its already provided
Logged
jdinner
Patron Class Member
Hero Member
Offline Offline
I'm feeling older
View Profile WWW
« Reply #9 on: February 24, 2010, 08:09:47 PM »
Because the electronic adapter is about $125.00. An ABS sensor can be had for nothing if you are building a replica chassis.
Logged
496fe
Full Member
Offline Offline
View Profile
« Reply #10 on: February 24, 2010, 08:19:50 PM »
So Jim... all I have to do is take the ABS sensor out of the hub and aim it at the driveaxle bolts?  Is there a test I can do with my multimeter to see if it is working?
« Last Edit: February 24, 2010, 08:22:54 PM by 496fe » Logged
jdinner
Patron Class Member
Hero Member
Offline Offline
I'm feeling older
View Profile WWW
« Reply #11 on: February 25, 2010, 04:10:32 AM »
I never tried it with a multimeter. I just used the speedo head as my tester.
Here is my initial mock up.
Logged
cliffscustomfab
Patron Class Member
Full Member
Offline Offline
cliffscustomfab
View Profile
« Reply #12 on: February 25, 2010, 09:41:51 AM »
oh great more wiring, another way for me to burn down my own build Embarrassed
Logged
 Logged
Pages: [1]
  Print
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Terms of Use | Privacy Policy | Sitemap
All trademarks and copyrights on this page are owned by their respective owners.
