Mad Mechanics - Custom and Kit Cars Forum Visit our friends!
Kit Cars Links
July 29, 2010, 01:03:56 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: No News is good news!
   Home   Help Search Login Register
Pages: 1 ... 5 6 [7] 8
  Print
Author Topic: CHRYSLER SEBRING Column  (Read 4789 times)
MacGyver
Patron Class Member
Hero Member
Offline Offline
View Profile
« Reply #90 on: February 02, 2010, 05:33:16 AM »
Since it is blinking slow, you may try an electronic blinker module. This should solve the slow flashing rate. There are also ones available that you can change the blink rate as well.
Logged
6.0nut
Sr. Member
Offline Offline
View Profile
« Reply #91 on: February 02, 2010, 08:05:58 PM »
OK. I wired the column just like Jets303 pictured, but still nothing. Its like there is no power going to the signal lights. Is there any way I can check to see if power is going to the lights and wires on the column? Huh Huh
Logged
 Logged
Jets303
Patron Class Member
Full Member
Offline Offline
G28lp640 reworked to near OEM!
View Profile
« Reply #92 on: February 02, 2010, 10:49:13 PM »
Im pretty sure the purple wire is 12v hot. I will check tm for ya
Logged
MacGyver
Patron Class Member
Hero Member
Offline Offline
View Profile
« Reply #93 on: February 05, 2010, 05:23:07 PM »
6.0nut,
Did you have any success yet?
Logged
ITALIANKNIGHTRIDER
Hero Member
Offline Offline
IKR SR71 BB Roadster
View Profile WWW
« Reply #94 on: February 13, 2010, 09:02:34 PM »
I found a emergency flasher button in a pontiac g6 ,it kinda look like the button in the Murcie ,who has finished their turn signals & emerg flashers on the Sebring column
« Last Edit: February 13, 2010, 09:04:07 PM by ITALIANKNIGHTRIDER » Logged
Jets303
Patron Class Member
Full Member
Offline Offline
View Profile
« Reply #95 on: February 14, 2010, 12:20:48 PM »
I have, they blink slowly but they work
Logged
ITALIANKNIGHTRIDER
Hero Member
Offline Offline
View Profile WWW
« Reply #96 on: February 14, 2010, 12:38:53 PM »
so it was simple to get the blinkers working ,was it any additonal wiring to get them going ,do you have the emerg. flasher button an are those working as well
Logged
Jets303
Patron Class Member
Full Member
Offline Offline
View Profile
« Reply #97 on: March 10, 2010, 02:18:46 PM »
Thought id post these before I erased them. All finished, everything works and looks great!
Logged
ITALIANKNIGHTRIDER
Hero Member
Offline Offline
View Profile WWW
« Reply #98 on: March 16, 2010, 02:02:14 AM »
nice job Jet303 working on mine thursday ,did anyone fine away to increase the speed of the flasher
Logged
Twilight Z
Hero Member
Online Online
View Profile
« Reply #99 on: March 16, 2010, 10:30:41 AM »
you should be able to buy a flasher control unit and adjust the flasher speed. they are used on sport bikes and import cars when you switch to led signal lights.
Logged
Whodeanie
Jr. Member
Offline Offline
View Profile
« Reply #100 on: May 10, 2010, 04:05:35 PM »
Ok, I finaly found this thread again  Grin I have been working on 4 of these now and I have a few things that will help make this a little more plug and play for all of you. I have made brackets for them so they can be bolted to the Fiero mounts as well as I have made a shaft adaptor to fit the stock fiero knuckle as well. I have been looking for one more plug for the wireing to make it plug and play as well.
if it helps I can set one up complete for 100 bucks with your column or I can provide one ready to go for 225.
I also noticed that several people have had trouble with slow blinkers, one of mine did this as well and it was an easy fix. just get a new blinker relay that is a little faster. I have the part # at the shop. I will get it for you all and post it this week.
D.
Logged
Twilight Z
Hero Member
Online Online
View Profile
« Reply #101 on: May 10, 2010, 04:12:44 PM »
how much shorter is the sebring column? as in how much closer is the steering wheel to the dash/gauges.
Logged
Jets303
Patron Class Member
Full Member
Offline Offline
View Profile
« Reply #102 on: May 10, 2010, 11:08:59 PM »
When I first installed my column it looked ok untill I put the body on. The column sat way to high. I had to move it in about 2 inches and down about 3 inches. It still sits a little high, but much better then it was.
Logged
6.0nut
Sr. Member
Offline Offline
View Profile
« Reply #103 on: May 10, 2010, 11:17:51 PM »
Looking forward to that blinker relay info  Grin Grin Grin.
Logged
Whodeanie
Jr. Member
Offline Offline
View Profile
« Reply #104 on: May 11, 2010, 05:07:00 AM »
it was the same way in my custom Choptop. I lowered mine by 2" as well on the mount closest to the wheel. I can include longer bolts and spacers for this as well.
D.
Logged
 Logged
  Print
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Terms of Use | Privacy Policy | Sitemap
All trademarks and copyrights on this page are owned by their respective owners.
