Jntramey's Amazing AD355 berlinetta build
  • Still have to cut out the Fiero trunk so I can mount the OEM muffler in the correct position. I cut off the Fiero trunk latch bracket in hopes I can re-use it for the OEM latch that I purchased (seen in above photo held in position by screwdriver.)
    • Comment
      • Rear air boxes and OEM style heat shield that I made.
        jntramey
        Senior Member
        • Trunk is all gone now. I repurposed a small section of the trunk floor though. I cut it off square leaving the last few inches at the top attached. I bent that backwards (towards the taillight support panel) and created about a 1/2" lip on the end were it would mate up to the tail light support panel. I'm hoping this will give it a little more support and serve as a tray/heat shield for my tail light wiring.
          • muffler approximately positioned.
            • The attention to detail is amazing.Awesome work.
              • yeah i seriously cant wait for this to be done, how much have you put into it so far? one question though, i noticed the wheels were way under the kit itself, are you going to actually have to fix the chassis for that or is is just not finished
                • The 355s are wider than the stock Fiero tire track. Some counter this with wheel adapters, some with offset/backspaced rims, and some folks go with modified/lengthened arms and axles. I'm not sure which, or a combination of these I will go with yet.
                  @Skilla000, Thanks!
                  jntramey
                  Senior Member
                  • nice build jntramey! Those air filter boxes work right? or just dummy ones?
                    Posted via HTC or Windows 10. Images hosted on [url]www.PixelsBin.com[/url].
                    • Originally posted by jntramey View Post
                      Possible to pull a mold of these? I know I would like a set
                      • Yeah, I can send them to Bart with a box of stuff I'm preparing to send him in a few days.
                        • Yep, the one on the left (driver's) is functional. the one on the other side is just for looks.
                          • Originally posted by bangsters View Post
                            • ...going to the inside...surfs Ebay...HE SEES IT...makes a dive for the credit card...he shoots...HE SCORES!!!!!
                              I like my new Challenge grill. Anybody wanna buy an OEM Ferrari standard tail light panel in factory Rosso Red cheap? I won't be needing it anymore.
                              • Does it have the talights in it or just the bare panel?
                                I need a red rear panel with those lights
