K1 Attack Build Diary
  • #31
    cool thx for the info, but their website is down....
    not cool that tehy dont help out , but i look forward to see this car finished ;9 especially cuz the 4.2 rs4 engine is my favorite one,
    • #32
      Nor can I :-) :-) Its all got a bit carried away recently with buying shiny bits !!! Never mind, probably only do this once, so am trying to do it properly .... Also trying to do almost everything myself which just takes ages !!!
      Couple more picture for ya :-)
      • #33
        Well bud, the attack is a cool as hell car, and do it slow and do it well. Also with the RS4 engine....its gonna be SICK!
        • #34
          Those welds are gorgeous
          • #35
            great work attackbuilder i will also be starting to work on mine soon.
            • #36
              REAL nice work
              • #37
                Thanks for the compliments guys :-) Have got a friend who is handy with a TIG welder which helps... I tack it all on and take it to their workshop and then its welded up on a full size surface plate :-) :-)
                Will be great to see another K1 getting built Carspancho, are u planning a build diary on urs???
                Got a 4 day weekend coming up so hopefully some more progress with the dry build!!!!!
                • #38
                  • #39
                    yes , i think so, i should get started in a couple of weeks, the bigest problem i see is the door hinges, do you have pictures of your door hinges? want to see what they look like
                    • #40
                      Hello Carspancho
                      I've kept the basic design of the original K1 hinges, but modded them where the door pivots.... One problem with the std car is the door wobble a lot. The std hinge has 2 surfaces that the pin goes through and it runs metal on metal.. I've made a trial one with 3 supports, that also runs with needle roller bearings and bronze bushes to control the side thrust.. It seems to work well, so i'll make some proper ones soon :-) The only thing is I had to do a little mod to the chassis screen support for clearance..
                      A couple of photo's for ya...
                      • #41
                        Did a bit of a mock up of the engine ancillariers... Gonna be a bit tight in there !!!
                        • #42
                          Bit more work on the column.... Just need to weld it up now...
                          • #43
                            thanks for the pict Attackb i don't think this design is going to work on mine because i am building mine on 96 camaro so i made lots of modifications and i think the door is going to hit the ft end, may have to design my own and that is going to be a bit#% but will see thanks again
                            • #44
                              Argh, didn't realise that !!! Will be very interesting to see how that turns out !!! I look forward to seeing ur build.. I ve seen some photo s of a K1 kit on an MR2 before, and that looked quite good..
                              How are u like size wise on the Camaro, as the K1 is quite small !!!!
                              • #45
                                +1
                                All I can see here is a top work !
