Cool, keep the pictures coming.
Mclaren F1
if you guys are talking about the center section under the nose it is not finished in these picture. I was too tried last night to finish that, but still wanted to share. I also still need to shape in the turn signals and a few other details. I will show more when it is a little further along. And yes it is amazing to see the shape come to life out of foam block...a big rush! Thanks guys!
You guys should take a look at this guys page he has about 30 Videos on his build ... Replica McLaren with a Audi V8
artiplastzabrze - YouTubeLast edited by T.M.C; 04-20-2012, 08:43 PM.
I ran a straight line across the back near the screen and it show the rh guard is lower than the left facing the car that is. the rest is spot on the air vent in the center is right 100% look to me like the guard need to be lifted about the same height as the vertical face on the air scoop, other than that a top job and good effort.
Originally posted by 917kit View PostI ran a straight line across the back near the screen and it show the rh guard is lower than the left facing the car that is. the rest is spot on the air vent in the center is right 100% look to me like the guard need to be lifted about the same height as the vertical face on the air scoop, other than that a top job and good effort.
Down load GIMP 2.6 free off the net open the pic of the car in GIMP in files under new you can scale up under image. you will see a ruler across the top click on that and it will give you a straight line , drag the line up or down same as line on the side... get back too me if you like
you can also click VIEW and click grid which will give you squares. be good to make sure you are straight on when you take a pic but the one you have seems ok
