LamboJayso's OEM Murcielago Build!
  • LamboJayso's OEM Murcielago Build!
    LamboJayso here sharing my OEM roadster build with the world. This is my second go around. I completed a G28 coupe last year. The donor I am using for this build is an '86 Fiero. This time I decided to go a different route with the body because there is just so much wrong with the G28. So far so good with building an OEM body on a Fiero. Below are pictures, enjoy.
    Easy does it.
    Here's the first build:
    Easy does it.
      Hi, You are right, "Experience is the best teacher". From the picture that's a very neat build. Keep it up.
        If its not a secret how much dis you pay for the body??
          Yes it is, thanks.
          $7,500
          Easy does it.
            Oem as original equipment manufacturer / used original panels or new from the dealer??
              Looks like John Watson out of Georgia.
                Yes i understand but this is not OEM, oem would cost 7500 only for a bumper
                  He means an oem dimension body
                    Car looks great what county in Jersey are ya?
                      Passaic County
                      Easy does it.
                        Just received premium parts from a premium friend. OEM dimension buckets, OEM dimension aluminum rings, and OEM head light lenses. Gets no better than that. All that's left is to wire her up. I also have Lp640 tails on order. Can't wait to put everything together and have her purring sometime this fall.
                        Easy does it.
                          That looks sweet! Great purchase!
                          Keep dreaming if you want to, I'm building mine!
                            Thanks Mitch, well now that I have the white buckets in the pics above, I won't be needing the Bierhanzel buckets anymore. They're $250 plus $22 shipping anywhere in the US of A.
                            Easy does it.
                              wow those new buckets look sick, you will have one of the best LP640 kits!
                              [URL=http://siteupp.com/]Create Your Own Website[/URL]
