I would suggest grinding or sanding the surface before applying epoxy or resin to your fiberglass. You are only going to get a mechanical bond to cured fiberglass. The epoxy or resin needs to have something to bite into.
U-pol "B" is what I use ... Similar like isopon p40... Works like a charm.. Buy an accurate scale for measuring hardner vs paste when making bigger batches...
Fibreglass kits like, for example, motip has.. I do not recommend quality of the resin and hardner ar not so good and above all they are more expensive...
What I would buy if I where you:
- RESPIRATOR(!!) ( +plastic bucket with cover to keep it in when not using it)
- Protective suit
- safety glasses
- box of rubber gloves 100 pcs
- box of wooden tounge supressors for mixing and applying
- cheapest bruches in various sizes
- save all your yoghurt cups for mixing
- vebtilator to blow out the air out of the garage or you will smell resin for 2 days..
- Around 5 m2 of 225 gram glass matt and 5m2 fleese
- around 3L of resin / mekp hardner
- gelcoat in case you wat to make molds
- 1L of acetone
- rollers small and wide for rolling air out.
- 2 tins of U-pol 'B' 1,85 L or similar product
- 1 large paper roll (like a large toilet paper roll) on your wall.
Last but not least:
-1 pin-up calendar for 2014..
I think when you have this sitting in your garage you will be able to get most small stuff done..
Thanks for all your help guys, seems this forum will be invaluable during my build
not made much progress this weekend, due to the issues I had with the handle mechanism :-/
strugging with adjusting them also so will have to revisit next week, gladly managed to get them bonded on thanks for your help :-)
heres a pic of this weeks progress :-)
Building F430 replica based on Toyota Celica 190 T Sport using kit provided by SRC Kit Cars, all advice gratefully received
[URL]http://www.madmechanics.com/forum/build-diaries/18184-c430-build-diary-based-celica-src-kit-cars.html[/URL]
Wow the body looks great , I like that you keep the factory metal structure
aNd just bond panels on top, should be a safe car with good door gaps etc
Hi cutlass442, that's the main reason I chose this kit, as it's my first build, it's a compromise as it's not 100% accurate but it's close enough for me, can't wait to get it done :-)
Really enjoying seeing the car coming together, just wish I had more time to spend on it :-/
