  • back from vaca and on to the REDO
    Go figure had a little issue with the fiero wiring for the door locks. Not good to have the 12v supply exposed
    Made a mount for the MES Swiss made door lock actuator.
    Mounted the Chinese door lock control module
    Video of the door locks https://www.youtube.com/watch?v=wsAp-LKQZos
    • the doors just keep going and going
      and still there is more to do .....
      • OMG look at that!!! Functional door locks and now a MIRROR is on!!! Dude, that door is starting to look whole! Glad to see you back at it. I know its been a process, but this car is going to be incredible when your done.
        • Labor of love for sure.
          I know it often seems like the more you do, the more there is to do unfortunately
          • Originally posted by G35Mike View Post
            Thanks! G35, A lot going on in the doors!
              20below thanks! for some odd reason I love working on this project Have no idea when its going to get done, LOL
              • Test wired the Cadillac Catera power mirror switch to the existing Fiero GT power mirror wiring, then the Murcielago side view mirror.
                https://www.youtube.com/watch?v=xMF2...ature=youtu.be
                Soldered up the catera switch to the fiero wiring, nice and neat
                • While waiting on a cable to do my inner door latch release, Fiber glassed the outer door skin in a few needed areas
                  The gaps were just to large for just dyna glass
                  The bottom of the door was also to short.
                  Also created a little flange on the door skin just above the handle.
                  Nice thing about fiberglass I can lay it up and go do some yard work, come back and do the next bit
                  • Also started on the Install of an OEM fiber glass rocker.
                    • Lookin' good!
                      • Originally posted by escaperoute View Post
                        Lookin' good!
                        thanks man! a slow process, but coming along!
                        • wow that rocker panel brings the side profile up ten notches!! Keep the updates coming my friend, your making awesome progress.
                            Yes the OEM rocker is waaay better!
                            • Well it looks like I haven't done anything on the car , but a lot of fiddling around with the outer door skin, fiber glassing sand etc to get the side view mirror to mount. I have had this door skin on the car, off the car so many times
                              had to add a flange on the upper part of the door, REDO the mirror mounting area, finalized my outer window scraper brackets (3m8115 then FGP). Added some wood blocks and bolts to mount the skin to get a better idea of how it all coming together
                              • spent most the day working on the floor in a horizontal position
                                Did some body work on the rocker and qtr panel as i cut out the G28 rocker /scoop and replaced with OEM replica
                                used dyna glass to fix the gap left where I cut out the G28 rocker, Between the qtr panel and OEM replica scoop
