G28 - Simple Mans, Simple REDO of an G28 LP640
  • #16
    Please post some pictures or a link to said pictures, I'm dying to see what your car looks like.
    • #17
      lots of caked on oil and oxidized aluminum. Seals were replaced, filter and pan gasket and a new torque converter.
      http://lamboclone.com/index.php?action=dlattach;topic=3575.0;attach=2180 2;image
      http://lamboclone.com/index.php?acti...ch=21804;image
      http://lamboclone.com/index.php?acti...ch=21806;image
      • #18
        Cleaned up some of the engine components. Used boiling water bath then aluminum de-greaser, followed up by dawn. Like the transmission, I soda blast them, then metal prep then paint. Obviously the gasket surfaces and or critical areas are protected from blasting.
        • #19
          Made some sheet metal pieces for the stretch area and sprayed the fire wall with Lizard Skin - sound. I really like this product, so much easier than dyna matt or an equivalent product. Will spray the Lizard Skin Heat shield tonight.
          • #20
            photobucket please. post some pics instead of links
            Yellow Vetter Carrera Gt-boxter based
            White Vetter Murcielago-boxter based
            White Gagliardi Vendetta
            Gemballa avalanche 911
            Team Mad Mechanics 2016
            • #21
              I'm really liking the Lizard Skin, it so easy to use!!! Final application of the ceramic heat shield at 4am this morning The firewall has a real solid sound to it now. Just have to top coat the product once it has cured.
              • #22
                Simple man. Did you spray your Lizard Skin on or paint with a brush? I used it on mu 355 engine bay years ago and planned on using it again for my 308 engine bay and when I sprayed it on the 355, I had to stop and clear my gun every 5 minutes as the ceramic pellets were clogging the tip. I will use a larger tip this time but wondering how you went about applying yours?
                Looks good
                Prova Countach 5000S
                • #23
                  Looks good
                  I bought the lizard gun. I read on some forums of problems using other guns. The tip on the gun is huge. Reminded me of spraying texture on sheet rock. It was the smoothest application... no clogs... took 20 minutes for each coat, which included mixing, spraying and clean up I'm going to have to think long and hard about ever using dyna matt!! No I will never use dyna matt again!!
                  • #24
                    Ah OK. I was hoping a primer tip would do it for me. I will have to look into that. I did open up the Lizard bucket tonight though and it isn't completely hard but it looks like many years have dried it out quite a bit. I will see if I can pull some out and add distilled water to it to see if it will loosen up or I wasted a large quantity of the stuff. Wasn't cheap way back then either. $120 odd a bucket if I remember correctly... I bought it when it qwas just new on the market.
                    Good luck with the build and keep he pics coming.
                    • #25
                      I got the Rodney Dickman poly mounts and the FerioRog 3800 engine and trans mounts in and mounted to the cradle! Nice products from both!!
                      • #26
                        Engine all cleaned up and resealed. FerioRog bracket to relocate alternator to power steering pump location worked great!!
                        here are the before shots a filthy leaking beast!
                        • #27
                          here are the after shots in the cradle. Must say the FerioROG brackets worked great!!
                          • #28
                            Did a test fit of the engine today. Need to move the upper engine mounts over a couple of inches.
                            Also have some suspension parts for cheap!
                            • #29
                              yay!! suspension!!
                              Ordered January 9th. Still waiting on Spindles and Brakes hopefully next week, cant wait to get this thing on the ground.
                              http://lamboclone.com/index.php?action=dlattach;topic=3575.0;attach=2196 6;image
                              • #30
                                Before the engine goes back in the fuel filler system needed a REDO!
                                Oops I turn the gas cap and it falls off.
