  • Made a flange on the qtr panel and scoop and welded up a frame for the NEW oil cooler and trimmed and fitted the wheel well liner.
    Pretty happy how solid the oil cooler mount is and the way the wheel well liner looks
    I need a piece of ABS 10.5 x 76 inches. this will be a cover and attach to the rocker and frame underneath to the car to give a clean look
    • Nice!
      Is there some rubber isolation to the oil cooler mounting to prevent stress cracks?
        Nice!
        Yes, 1/4 inch rubber washers.
        • looking good my friend. Steady as she goes.
          It's a never ending battle of making your cars better and also trying to be better yourself. - Dale Earnhardt Sr
          • Trying to put to bed the wiring on the drivers door
            ran about 18 wires into the door via a rubber grommet, then started to wire everything up.
            Courtesy lights - door opens lights come on
            Door Lock actuator
            • Window motor wiring - My switch went bad and the connector cracked had a 118 mile round trip drive to a pick n pull. loaded all the connectors and switches they had .
              https://youtu.be/yMtoEphTQXU
              Side view mirror - had the thing working weeks ago. spent hours second guessing my catera to feiro to lambo chart. Long story short the wire on the drivers side had been cut by someone Ran some new wires and got them working
              Also added an $8 mirror folding system. Here is a video.
              https://youtu.be/bkCOIkax8fs
              Need to add my interior actuator switch and to solder it all up
              Fiero and Remote lock unlock and folding mirror system
              • After finishing the door wiring, I moved on to the engine.
                A shift system was purchased from Joe the fiero king and installed so you have to depress the brake pedal to before you can push into PNDR. It a nice set up and I'm glad I have it for the build!
                • With The Fiero Kings shift system in I fired up the engine and it is running rich. Replaced the MAF, TPS and IAC sensors and adjusted the fuel pressure.
                  I wanted to run a scan but the Prior Owner removed the ALDL port
                  does anyone know the what PIN to wire up the ALDL port There are 4 wires unattached by the PCM
                  • ot a chart from Ryan at Sinister Performance LLC, a very helpful person.
                    http://www.gmtuners.com/files/Fiero_L67_PCM_wiring.pdf
                    With the PIN layout for for the OBDII port wires.
                    PIN 59 Purple wire was one of the cut loose wires
                    PIN 15 tan is MIA
                    • Awesome! great job, u r the man! Best I ever see
                      • Again hope t c more
                        • Originally posted by LLLPPP View Post
                          Again hope t c more
                          thanks LLLPPP!
                          • Well Having been down with injuries to both thumbs for 7 weeks, project REDO has been restarted
                            Finished the IDLA port and the wrapping of the wiring harness
                            • started on the engine hatch. The REDOs G28 hatch had seen batter dayz, so I went with an OEM replica.
                              The angles on the body are not right. The gap from the hatch to the body is 1/2 inch.
                              Fiberglass, and some sanding and the gap is 3/16 of and inch. Will use some dyna glass to dial it in later
                              • Nice work !!
