As usual, your improvements to this car is just a pure work of art. Cant say enough good things about your build. Keep up the great work. Congrats on the milestone of moving the car under its own power. I know that has to feel great after all your labor of love thus far.
Originally posted by G35Mike View PostAs usual, your improvements to this car is just a pure work of art. Cant say enough good things about your build. Keep up the great work. Congrats on the milestone of moving the car under its own power. I know that has to feel great after all your labor of love thus far.
Spending some time tying up a few loose ends.
Fixed the leaking transmission line, bled the Rad system. Adjusted the throttle cable, adjusted the brake light switch.
Then body work and flat black paint on the back side of the bat wings, and finished the gap work. For now anyways
Started to look at modifying the dash but decided to change directions to work on the HVAC
Spending some time tying up a few loose end.
well the REDO came with a groovy HVAC controller. Plugged it in and was surprised that actually controlled the zones of the system. Fan didn't come on.
Took off the cover to the Evaporator, more maple leaf seeds and mice poop than pictured. Took off the cover to the heater core more goo to clean.
Bench tested the blower fan an it is dead.
Parts ordered
Blower
Blower resistor module
Heater core - didn't like the aftermarket one as it was a little smaller than OEM
Two heater hoses for car with A/C
Cleaned up pretty nice.
Tried to fire up the blower motor and no worky.
Started with the relay and it has power.
Deja vu on the wiring, Tape removed tells the tale.
Checked out the relay connector, lots of corrosion. Luckily was able to grab one from the parts car.
After the repairs tried the fan switch but still no worky.
Replaced the Rad hose that was leaking. Will look for a gates hose if it leaks again
My gal and I, cleaned out the shop, and washed down the floor.. Radiator fluid smell is pretty much gone.
A break in the weather and was able to cut off the passenger door skin. Hope to after the first of the year. Fun times ahead!
