  • Over all I like the FGP parts but they put this nasty black primer on. The gel coat is to thin. So sand off the black primer
    Once the black primer is removed you can see all the things they had to fix. Used some rage to fix some issues
    Pinholes
    • drivers rocker.... a few more adjustments to go ??
      • Sail panel II
        a lot of work but worth it
        now I have both sides
        I have a Jose Ortiz fuel hole? and a fiberglass lid for sale , Cheap!!
        Sail panel II
        • The car is really beginning to take shape!!! Nice to see your still at it. Been off the site for a while. Just catching up now. Keep up the good work bud.
          • Body is really coming along. Looking good.
            • Originally posted by G35Mike View Post
              thanks Mike!
                thanks Don!
                • Got the fuel lid on, added an end piece so in can be fastened with a small recessed screw to the body.
                  Added studs to the driver sail panel, dura glass then CSM
                  Anyone know how the actuator is wired up? I can get it to open, is the close wired into the ignition switch?
                  • front trunk lid
                    while back I spent some time modifying an OEM replica inner front trunk lid to fit the G28. I abandoned that and started over as it just wasn't working
                    made a metal frame, cut bent and welded to match the curve of the fiberglass lid ...treated for rust prevention. Added Latch to frame
                    Used panel bond to attached to fiberglass lid
                    Made foam inner trunk lid glued in placed, sanded to shape
                    Fiberglassed over that
                    Rage gold then Rage Ultra to smooth everything out- love the rage ultra!!!
                    Painted flat black
                    here is a picture of the REDO trunk when I went to look at it to buy it.......
                    what was I thinking?
                    what the REDO Looked liek when I bought it
                    • Hi Simple Man
                      Holy Shit !!!! I buzzed through some of your build and I am going to say it Again Holy Shit , you have more patience than anyone I know , kudos to you for sticking with it , I don't think I could have .
                      It looks like it going to work out in the end , the car you started with is the reason I think that the phrase Kit Car got such a bad reputation .
                      Good job on Redoing everything , hang in there !!!!
                      Cheers Falcata
                      • Originally posted by Falcata View Post
                        Hi Simple Man
                        Cheers Falcata
                        lol Falcata, thanks for reading my build thread! I jut keep plugging away on the REDO.
                        • outer door skin take #2
                          new G28 skins came in
                          Mounted my outer window sweep a little different then the first time
                          • taking my time to try an get the fit and finish to look proper. One must resist the urge to go quickly.....
                            have a few adjustments to make...sand here, sand there....
                            • So much progress being made. Your car is certainly beginning to take a real shape here. Well done.
                                thanks G35!
