  • Used the 3m panel bond, waited 24hours took the clamps off. Pretty happy how it came out, of course there is a ton on body work still to do on the door.
    • Nice.
      Someone told me a good tip is to use the thick stir sticks from Home Depot under the clamps or vise grips to spread the force so as not to get dimples or low spots.
      • now on to the qtr panels.
        have some issues here, not sure if it is because these are roadster doors, but I did have to make quit a few adjustment to the doors to get them to work. OR possibly operator error, or a combo of the above, But whatever the cause have to make it work and look right
        going to make a mold to make the part to either cover the existing mess or come from below. gotta think about it.
        • Problems - The REdo has modified OEM replica sized batwings The bat wings are not as wide as the G28 batwings. This leave about a two inch gap that has to be filled
          The Door skins are from Carl in RI and are a bit different than the G28 doors. this difference is makes the top of the door stick out by about 3/8.
          Plus the top of the qtr panel about mid point has a hump. Not sure how this is, but it is
          • Made part for top of Qtr panel,
            3m 08115, yeah I spread the glue before clamping
            CSM after Clamps removed and CSM underneath where I could reach
            Duraglass,
            Rage Gold
            • sanding and sanding.
              Still a ways to go but progress
              • door gaps, a little tight but good for now
                • made some headway on the body work today
                  • taking a look at the side shot of the REDO vs OEM, The angle of the scoop seemed off.
                    cut off some material sanded, refit, cut off some more sanded etc, until the angle seem right.
                    Made a flange on the Qtr panel to affix scoop,
                    • You're throwing together some amazing craftsmanship. That is a ton of work.
                      bob
                      • Originally posted by RCR View Post
                        bob
                        Thanks Bob! yes it has been a lot of work but I enjoy it!
                        • after a month of working on home projects good to be back on the REDO
                          The lower portion of the driver door was sticking out too much when compared to the rocker panel.
                          Cut the bottom of the door, attached blocks and screws to bring the lower portion of out door skin in.
                          Fiberglass rage ultra and sand
                          Now a nice smooth transition from the door to the rocker
                          • pretty close on finalizing the gap between the rocker and bottom of the door.... for now anyways
                            • spent some time clamping the front bumper and making adjustments to get it to look right....
                              probably make a few more adjustments
                              • This is a crazy amount of work to get it to look right. It seems like you would have been better off having a body cut from foam on a CNC and making panels from scratch.
