  • Had a set of G28 door cards which are far from the look the REDO needs. Also a set of mangled OEM replicas that were cut in the center to make them fit the opening of the G28
    • Starting with foam to make a plug.
      Lots of adjusting and then bondo sanding etc.
      once the plugs were done made some molds
      And had to sand the molds
      • many adjustments to the parts pulled from the molds. Cut and adjust, grind fiberglass repeat!!
        lost track of how many times and what was done to make them decent.
        be so much easier if G28 was the same size as OEM
        http://lamboclone.com/index.php?acti...ch=31092;image
        • The REDO door cards
          Passenger side turn out pretty nice - learned from my mistakes on the drivers side
          Driver side - going to have to make another mold of the main piece for the card as it is pretty chunky as it was the first one I did
          • Your motivation and the amount of time and effort you put into each and every part never ceases to be an inspiration!!
            • Absolutely amazing and inspirational work! Outstanding!
                thanks 20 Below
                • Originally posted by luke.jenner View Post
                  Thanks Luke Jenner
                  • door car installed and on to fitting the OEM replica dash
                    A Murci Me instrument pod came with the REDO
                    had to rework the opening to make it fit
                    Using a template, The dash was cut in two places and fiber glassed back together
                    Then adjust the width using foam and fiber glassing
                    • The OEM replica dash ends had to be cut off and a portion of the dash removed so it would fit length wise. The space and angle has to be right, so hopefully looks like the OEM car
                      There was some empty space on the top of the dash that had to be filled in, more fiber glassing.
                      • Need a airbag piece for the passenger side.
                        Not sure if I make a mold for this after final adjustment, and possible glove box or just delete it all together
                        • then a bunch of body work.
                          • Nothing like work to get in the way of progress on the REDO
                            back at it after about 3 weeks. Lots of fiddly issues in mounting the the dash, console, grab handle and the lower dash panel. Fabricated some brackets, blah blah blah
                            If work doesn't get in the way, it will be on to the drivers side
                            • Looking good!
                              Pesky life always getting in the way of the fun stuff!!
                                Looking good!
                                yes it does ! lol
