Im in need of help. I have a lamborghini lp640 replica. Its donor is a fiero 86gt. My car is running stiff and steering wheel hard to turn. Is there an area in the car where i can put power steering fluid in. I looked every and i couldnt find an area. Please help if you can with pictures
Fiero power steering help
No, you don't have to replace the whole rack and pinion, just add an electric power steering motor in-line in the steering shaft (the shaft that runs from the steering wheel through the steering column and down to the rack and pinion).Without talent experience is worthless
It doesn't cost a lot if you can do the work yourself. If you cant, then you're stuck.
Look at this thread of a guy who did it to his fiero.
http://www.fiero.nl/forum/Forum2/HTML/138106.html
I know the HHR and Cobalt SS both have electric power steering which can be adapted to fit the fiero easily as welllWithout talent experience is worthless
Check this out also, I think its the cheapest and easiest way
http://www.fastfieros.com/tech/eps__...r_steering.htmWithout talent experience is worthless
Originally posted by murcie-me View PostCheck this out also, I think its the cheapest and easiest way
Originally posted by red328gtb View Post
Originally posted by red328gtb View PostWithout talent experience is worthless
