Miura powertrain phase begins!
I’m now embarking on the powertrain phase for the Miura project. I’m doing this prior to completing the chassis and body phases as I want to prove out that I can make various aspects of this very unique transverse engine powertrain approach actually work. My experience from the computer software industry is that when venturing into the unknown or risky territory, it’s much better to “fail fast”, innovate and recover than to attempt a “big bang” from which failure is most often fatal for the project.
In preparation for the powertrain phase, I moved the Miura chassis outdoors for some “big picture” viewing and to take some progress photos.
And here’s the part that makes me most nervous as it relates to powertrain. The engine, transaxle, and drive axles all must fit into this relatively small compartment in the chassis.
The first thing I want to prove is that the intended powertrain will actually fit. So here’s some pieces that arrived this week.
It’s a Ford 5.0 L Coyote engine from a wrecked 2017 Mustang GT with 15K miles on it. I chose the DOHC Coyote engine as the original Miura had a DOHC engine and anything less wouldn’t feel right. My first impression is that the Coyote is a very wide engine at the wide part of the “V”. I sure hope it fits. :-)
I bought it as a “Master Kit” which by the 1653 lb. shipping crate weight includes about half of the original car by weight. I don’t anticipate using all those parts in the Miura but I figured that given all the electronic wizardry involved, it’s better to have the whole engine/transmission/wiring harness setup and whittle it down to what’s actually needed for the project.
After 3 years in the making, I also picked up the Pete Aardema inspired and designed transaxle this week as well. Kevin Braun is the master machinist who machined/carved the aluminum billet into a precision transaxle. The cast aluminum bit in the middle is a Tremec TKO 5 speed transmission.
Now comes the job of mating the engine and transaxle up and do a trial fitting into the engine compartment. If it fits, then it’s on to fabricating mounting brackets. If it doesn’t fit, hopefully it just a matter of trimming off some spare chassis material … or time to innovate.
