Originally posted by Bloozberry
View Post
Modern-day Miura
Gas Tank/Coolant Pipe Mounts
While re-installing the gas tank I decided to take care of some other issues I had spotted. Specifically, to protect the tank from chaffing and finish up the coolant pipe hangers that are integral to the gas tank mounts. When I removed the tank to lower the top, I had to pry it downward as the sides had started to chafe against the aluminum plates surrounding it and this appeared to be making the tank stick in its compartment.
Here’s a picture of the compartment where the tank goes. There is of course a cover over the top of the gas tank that is not in place when the picture was taken.
After tank removal, I verified that the tank sides were chafed/scratched and to a degree they should not be given the car has only been moved around on a trailer and never driven. It was apparent that the aluminum to aluminum contact needed a cushioning layer in between. I bought some marine grade vinyl upholstery material and lined the tank compartment with it. Unfortunately I forgot to take an “after” picture prior to installing the tank. Hopefully this material will also prevent any banging or squeaking that might have occurred from a metal to metal contact point.
The gas tank installs from the chassis bottom and is held in its compartment by 3 sheet metal plates that also hold the coolant and AC pipes as they pass under the chassis. The plates that came with the chassis are made from Al 5052 .063 and were very nicely cut out on a CNC router. I had two concerns with them; 1) the 1 ½” coolant pipes pass through and are suspended by holes that are only two metal thicknesses wide (so 1/8 inch) thus susceptible to extensive wear at those points, and 2) there was no protection from road debris contacting and damaging the aluminum pipes.
My solution for more robust coolant pipe hangers was to add rounded sheet metal saddles into the front and rearmost plates. I think the smaller heater and AC pipes will be fine with rubber grommets inserted into the holes.
To keep all the plumbing safe I decided to make some debris shields. They act as a “skid plate” if you will and provide full coverage for the pipes. To keep the shields from flopping around in the wind, the sides were bent up and a half round bead rolled down the middle.
With the debris shields in place, it adds a nice finishing touch to the bottom of the car.Joel Heinke
