Falcata
More on the front end , The first thing I did in glass was a copy of the bottom of the hood , mostly to test my set up and make a part that didn't really matter , I had some old resin from a boat job I had done a couple of years previously , and was sure it had been below the recommended temp in my back shed , as expected it had lumps etc. so it didn't turnout very nice . Headlight buckets and the front bumper cover support , the first pic is pulling the PVA off the part .
So the center red piece , the headlight buckets and the black bumper ( factory foam ) part will be glassed as one part . I got excited to see some shape in the car and two part foamed the nose before this happened , which is alright because I will probably have to add tabs or put fasteners in it anyway .
As you can see I kept the factory tow hook also .
More front end stuff , so here you can see that the front support piece in the second pic and the second last pic without the headlights in , red and the grey parts will become the one , I will have a two piece mold so i can release it , the seam will be the top front edge just below the headlights .
So when you get your new body , you remove the factory bumper cover , fenders , headlights and hood .
Install the front bumper spacers ( 2 inches ) and install this under the nose part first .
More front end stuff ,I made fiberglass copies of the stock front fenders to use as the base for the new fenders , because I want to use as much of the factory mounting points .
Also made a glass copy or the wheel arch , save figuring all that out as well , I used small diameter steel round bar to set my top edge and flat bar to mount it to the top of the existing fender .
Then I made templates out of Ram board , (it's like thin cardboard ) then transferred them to 1/4 inch MDF bucks which get glued on , as you can see the outer wheel arch is set out further on blocks .
It looks easy in the Coles notes version here , there is weeks and weeks of work in these fenders , and more to go .......................and I wondered why nobody had done this before ....
Next is to prep for the two part foam on the fenders , I made a border around the headlights with some aluminum flashing , the first time with the foam I was too excited about seeing some shape in the car after months of building the rear inner and outer hatch covers , i buried the lights in foam , it was a total pain in the butt to dig them out without scratching the lights . In the last picture I will explain in the next post why the fender does't go to the door , that little pocket at the top is to hold the foam .
Still lots of shaping to do .
