  • #46
    Re: DNA 3Sixty Build Diary - CdRsKuLL
    Originally posted by CdRsKuLL
    not a problem m8, u have a good curry :-) I'm busy sticking things on ebay at the mo, having a clear out to save some pennys up for some more car bits :-)
    Steve
    Steve on the pre 03 cars the front lights have switched earths but I think yours has dedicated loom so if it is a face lift MR2 then its easier to wire
    • #47
      Didnt know that, Thanks.. I did however leave the bulbs in the wiring loom like you suggested so it should only be acase of extending a few wires, not a problem at all. :-)
      OFF-TOPIC alittle bit anyway
      I think I've found a place closer to me for retrimming my seats / door cards and gear stick gater.. cant decided between cream or black with red stitching, maybe the latter as it will be more pratical.
      I did attend a track day a month or two ago and took some pictures of a 360 spider. Below are afew which shows the black and red stiching, but also shows placment of badges etc, which might come in handy for others -)
      THE REAL DEAL !!!!
      Have fun
      Steve
      DNA Owners Club - DNA Kitcar Related Website
      Extreme Owners Club - Extreme Kitcar Related Website
      • #48
        Great build thread! Keep up the good work. The time estimates are really cool.
        BTW what is the thing coming out of the front of the grill here?
        Is that for jacking the car? I bought a larger nut to weld to the front frame of my car and a large bolt to stick out of the front like that. Thought it might work to jack it on because of how low the car is (hard to get a jack under).
        http://www.madmechanics.com/forum/bu...todreamer.html
        • #49
          Its a tow hook, they need them fitted on trackdays incase they come off and need pulling out / back to the pits, part of the trackday rules
          • #50
            You could drill out the top rivet to 6-6.5 mm as shown in the red circle ( this applies both ends ) it is one of the bolt holes for the adjustable light carrier. There is another hole that goes thro the top of rhe bumper bar but you can do that when you've got the carrier.
            The 10 mm hole between the blue lines is the right hand hole for the aluminium carrier for the front of the kit ( one to the left as well ) When you drill these holes make sure you use HIGH QUALITY drill bits ( not cheap crap ) and not too fast or you will blunt the bit and harden the metal of the bumper bar in the process.
            Technical and hands on engineer
            • #51
              Looking at each end of the bumper bar there was a bracket bolted to the marked holes. Remove these as they get in the way of the light carrier.
              You could also remove the bonnet catch assembly ready for relocation.
              • #52
                thanks m8, easy jobs :-) will only take afew mins. I still have all my stuff from when I was a mechanical tech 14 years ago. So this aint a problem at all. Every little helps :-).
                Steve
                • #53
                  i have tried to put up some more info with pics but is not happening
                  • #54
                    red dots indicate areas to key prior to bonding
                    • #55
                      that took about 10 attempts!!!!!!!!!!
                      • #56
                        remove the mirror assembly as well but save
                        • #57
                          dude ur car has chicken pox!
                          • #58
                            Hi, cheers for the dots. Will get them parts at the rear keyed in ready :-) Will grind the doors when I'm ready to do them. I wonder if my mouse sander with 80 would do a fine job for the rear bit.....
                            simply cant wait to crack on with it :-)
                            • #59
                              what do you mean "key"? Are you talking about drilling a hole? Sorry I didn't understand your post...
                              • #60
                                great progress, can't wait to see more
