More pics......
Dale's Koenig build progress
Originally posted by Daleford View PostJust to keep this thread alive I am posting a big howdy to everyone. I have new pics of the Koenig attached.
Headlight covers. I used acrylic which breaks easier but is nicer to buff and keep clean. These have 1 mounting stud in each corner that is hiden from view and a 1.5 inch black border sprayed on the bottom side. I gotta say, these look better that a lot of Willy Koenig's covers.
I recently got a TR replica. The PO removed the pop-up headlights, motors, and linkage. They replaced it with ... something.I think the original intent was to have something similar to your lights, but their finished product is not even the same sport, much less the same ball park as your's.
I'm trying to decide whether to try to reinstall the old pop-up motor system with a TR replica enclosure (like Bodyman has), or just keep what I have and cover them with a nice looking cover like your's. I prefer the pop-up look, and found a set of light enclosures... however, I'd still need to find the motors, linkage, hinges, a method of mounting the lights inside the enclosure, etc. Long-term, that is what I'd like to do.
For the short-term, I'm thinking about just covering the four lights with plexiglass, similar to what you have done. However, I don't know how to make them look "right". You have achieved that!
Do you have more photos showing your light covers? It looks like two layers... maybe fiberglass, aluminum, or steel sheet on the bottom as a frame, and acrylic on top?
Did you put the mounting studs into the frame, then cover the frame with a sheet of acrylic (after painting a border on the acrylic to hide the piece of metal)? Or were you able to attach the mounting studs directly to the acrylic somehow?
I hope you don't mind my questions. Your car is built to the level of quality I would like to see mine become.
Drew: You have it all figured out exactly!
Do you have more photos showing your light covers?----- I don't have any other pics that I took at that time
It looks like two layers... maybe fiberglass, aluminum, or steel sheet on the bottom as a frame, and acrylic on top? ----- Yes, 2 layers, and it is an acrylic frame and top.
Did you put the mounting studs into the frame, ------ Yes
then cover the frame with a sheet of acrylic (after painting a border on the acrylic to hide the piece of acrylic)----- Yes
Only problem was I had no space to put nuts on the studs from the bottom so I used alligator clips
Oh, and a new problem they are now delaminating at the corners. I used urethane for bonding. Maybe you should use a better product for that. Maybe epoxy??And the joke is,<br />when he awoke his,<br />body was covered in Coke fizz !
Thank you for the reply. I'm so glad you returned to the forum.
Originally posted by Daleford View PostDrew: You have it all figured out exactly!
lol Just kidding, but if you don't mind taking some detail photos for the assembly, how it fits over the light "tray", how it intersects with the hood, etc, I would really appreciate it!
Originally posted by Daleford View PostIt looks like two layers... maybe fiberglass, aluminum, or steel sheet on the bottom as a frame, and acrylic on top? ----- Yes, 2 layers, and it is an acrylic frame and top.
When you say "alligator clips", do you mean the electrical wiring things?
Anyway, thank you for the reply!
By the way, are your light "trays" (the horizontal portion of the light assembly, and framing around the lights) home made, or did you retrofit one from another car?
Mine are home made. There is no way to adjust the beams, no framing for the lights. The four rectangular lights are "glued" into place with some kind of black silicone sealer, or something. They don't really hit the road way very well, and the high beams are especially off-aim.
How my car looks with the high beams on:
Like I said, long term I would like to install the popup system, but I can't take on that project yet.
My light trays are part of the hood, as are the fenders - 1 solid one piece fiberglass tilting hood.
The "buckets" with adjusters are attached to the rear of the light trays. I think they are from an older Sunbird.And the joke is,<br />when he awoke his,<br />body was covered in Coke fizz !
Originally posted by Daleford View PostMy light trays are part of the hood, as are the fenders - 1 solid one piece fiberglass tilting hood.
I'll Google images of the Sunbird, and may try to find used "light bucket" parts on eBay. If they are close, and cheap, I may order a set to play around with.
I look forward to seeing your detail photos, and thank you for the information about your lights. I'm about to put coolant back into the car (replaced the coolant hoses after a blowout), so then I can hopefully start looking into some ways to improve the appearance and realism of the car.
Your pics are on my list. It is just that the rear of the car is jacked up now and I can't open the flip front.
The Sunbird was probably from the mid-80's and had the smallest size rectangular headlights. Lots of those at the U-Pick.
Easier to send pics to your e-mail address. PM me with that.And the joke is,<br />when he awoke his,<br />body was covered in Coke fizz !
It sure was a beautiful car. Thanks for sharing the ride.
(What's next??)
BobBob custom '84 Fiero SE --->>> custom F408
