Infiniti G35 Coupe
  • Infiniti G35 Coupe
    What makes a good candidate for a Rebody Kit?
    Re: Infiniti G35 Coupe
    whats the wheelbase etc ?
      If you're asking what make/model makes a good donor:
      Availability
      Low cost
      Performance Options/ upgrade availability
      In some cases ease of chassis stretching/modification. Unibodies are not ideal, but can be done.
      I think the first two limit the G35 from being a good donor. Just my $.02 of course.
      Of course, if you're asking if a specific car is a good choice, that would be low miles, little rust, straight frame.
        I was always so blind to see this! The Fiero is the best donor available! Unless you want to do a Micky Mouse job of throwing a body on a car steer clear of everything else. Fiero is cheap, theres plenty of them. You can safely and very very easily lengthen the chassis. You can upgrade the suspension, easily fit a new engine, update brakes and whatever you want very simply. When all is said and done with all the upgrades you will still be cheaper then buying a G35 as a donor. Not only that, with all the upgrades you no longer have a Fiero you have a car that is up to date with everything being precise to your kits needs.
