LP640 Door Handles
  • LP640 Door Handles
    anyone know the width and lenght of the actual door handle?
    Re: LP640 Door Handles
    outer door handles ;D
      Length is same, width is 1/4" wider. OEM wont fit TG doors, the top shoulder is to thin.
        Great thanks. Im having my body guy widen the top shoulder. Mike, do you know the Fender shoulder width? Green says it should be about 1 5/8"...
          pm sent
            Mike, pm sent. Thanks again for your help!
              Here is a pocket installed. Since the shoulder is 1/4" narrower, the handle must be 1/4" narrower to fit. Hope this helps.
                To widen the shoulder, it must be widened inbound on the door and body. If you do this, you can also add the notch where the bat wings sit.
                  You read my mind about the notch in the bat wing Thanks again for all your help.
