Help with fibreglass mould
  • Help with fibreglass mould
    HI iam trying to make a mold of a naca duct from fiberglass, but the problem i seem to be having when i lay up the fiberglass matte is, when the fiberglass goes over a right angle, it starts to lift from the gel coat when the resin starts to dry.
    Any advice would be very much appreciated ???
    www.lazymansguideto.com<br /><br />The Lazy Way To Learn
    Re: Help with fibreglass mould
    Dont use matt when going over a right angle, or any corner. Use the thin woven cloth, and add CABOSIL or another thickening agent to the resin. The cloth will conform smoothly over the edges, and the thickened resin wont allow it to lift away.
      if all you have is Matt tear it into small strips an pieces wet the gelcoat first then lay the strips in this is a longer process but after 9-10 strips you can see what you are doing ,if you have some fiberglass veil ( its like tissue paper for the first layer then go over this with the strips this will keep the gelcoat from having air bubbles on the first layer Cabosil will do the same thing mix like a putty ,you put this on shart angles or tight corners
      this is a pair of white gelcoat Murcie door panels made tonight the sharp corners were done with strips
      the coupe deck lid was more open an easier it had several 90 degree truns on it
      this new hood tonight was simple an fast ,just had to roll out the small air bubbles in the first 2 layers then i put on 4 more an rolled 1 direction for the rest of the bubbles this will be the murcie GTR HOOD i cut up an ad the scoop over it
        you can also use thinner matt (.75oz) for the first 2 layers. It also help if you cut the matt to the shape of each faces and laminate them before turning corners with the same piece of fibreglass.. As mentionned in the previous post, thicker resin also help. If you don't have any filler, you can use a small amount of body filler and laminate over before it gel. You can also mix bondo (without hardener) with polyester resin and then catalize it with MEKP (your regular resin catalist). I also used to keep sanding dust from body filler and use it as a resin filler (works well)
          thanks for the helpguys illlet you knowhow i got on
            new black hood
            white LP door panel
            mold waxed an ready to go again
