Audi 5000 trans problem
  • Audi 5000 trans problem
    I can't move the shifter into 2nd, 4th, and reverse anymore. 1st, 3rd, and 5th are OK. Internal linkage problem?
    Re: Audi 5000 trans problem
    What about reverse?
    Could just be cable adjustment.
      MM - the shift stub just will not turn clockwise. I even unhooked the linkage.
        So its something inside.....than Iīm afraid I canīt help you much.....check Jdinner
        regards
          Broken case. Pinion shaft is now too far rearward. This is why made the case plate.
            The tough part is that I haven't even driven it! Delicate things eh?
              Good news! I am retarded. I didn't take ALL of the shifter off like I said I did. One of the arms was fouling the clevis. It really works well now. You can shift it as fast as you can move your hand now, with no cheater gates. Thanks for all your helps. I am still going to do the upgrade, but now the pressure is off.
              Brian
