Im new in this forum and replica builds
  • Im new in this forum and replica builds
    hi
    im new in the forum , i have several experience in fiberglass works but i never make a replica car from scratch and now i want to make one
    i choose a lamborghini murcielago to make my first replica from scratch
    i have made a 3d model in the software called rhinos
    but i have some questions to make the full size model
    how many sections are necesary ?
    which is the best foam to make the model ?
    and what bondo or filler can i use to smooth the surface ?
    thanks
    Re: Im new in this forum and replica builds
    this is the model i make in rhinos
    sorry about my english but is not my natural languaje
      checa tus mensajes
      check your pms
        i make in cad a section each 200 mm
        dou you thinks is good ? or is to much ?
          Looks good to me. Now you have to scale it up to a 1:1 scale and make a plug to lay your fiberglass on to
            I suggest you just buy a complete body. Taking the shell and making the doors and decklid seams and returns will be a huge amount of work. It looks great thus far, but I just don't want to see you lose motivation on the project halfway through - you have a lot of work ahead of you! If you just bought a complete kit, you'd be halfway there already.
            Also, are you sure you want a murcielago, and not the updated murcielago LP640?
            Best wishes with the project; the 3d model looks great =)
              i have front 3x templates 100mm distance and next per 200mm. It is very very more work. It is fact true. But if you manage to succeed, you will be able to tap on the chest .... (maybe)
              .... only cutting, drawings templates took 3 months ...
              And that is the creation of templates, including the preparation of wood, the least worse :-( ... will reshape using foam and other materials true shape ....
                and now al the sections
                i thinks if there are no mistakes in cad
                i will not have problems of the shape in real shaping
                  Good luck with your build but before you get too deep into it, I would def upgrade the bumpers to the Lp640 style. It looks ten times better
                    spotter_25
                    Do you have any manual where explain how to make the sections of 3D model?
                    thanks
                      Originally posted by patata
                      spotter_25
                      thanks
                      no i idont have , i just use the tool in rhino
                        spotter_25
                        thanks
                        What tools are used? Could you tell me the command? Thanks
                          is just the word seccion and you select the piece to seccion
                            good luck your going to need it
                            http://www.greenpacks.org/2010/01/11...a-lamborghini/
                              Good luck buddy, I hope you fulfil your dreams.
