Alternate coilovers.......... :) Just a thought
  • Bottlefed
    Re: Alternate coilovers.......... Just a thought
    Originally posted by Tom Sawyer
    These are designed to suspend the rear of a minivan. Even if you could customize your suspension to accept them, the ride height is not adjustable (and would be high), installing an eBay 400# spring China coilover sleeve kit would make it bouncy as hell (damper would no way control a spring that heavy) and with the included spring you'd have minivan suspension performance. They look like they could be useful, but they're not designed for your intended purpose.
    Per the tittle.... Just a thought..
  • Tom Sawyer
  • VF1Skullangel
    I wouldn't. They look nice but looks can kill.
  • KISSIMMEEDIABLO
    if you double up for the rear...you just spent more than you would for the right coilover
  • Bottlefed
    from the description they look like a primary shock for the rear of a mini van
  • txbuilder
    Are those designed to be helper springs rather than the primary spring?
  • Bottlefed
    I dont think they are............, and I was looking for the weights, but couldnt find em. Oyr coule probably use an ebay universal coilover kit for like a honda to make them somewhat adjustable.
  • Jets303
    Are those adjustable?
  • Bottlefed
    started a topic Alternate coilovers.......... :) Just a thought
    Just thought id share.....I thought this would be a decent alternative to expensive coilovers. Looks like there running about $80-100 a piece.. you could probably double up on then for the rears.
    2007
    Ford
    Freestar
    Base Mini Passenger Van 4-Door
    3.9L 238Cu. In. V6 GAS OHV Naturally Aspirated
    Relation Per Car Qua...
