Adjustable springs
  • Adjustable springs
    OK, probably the most stupid question I have asked, but my mind has gone blank..
    If I want to lower one/both side(s) of my car, do I tighten the spring on a coil over or loosen it?
    Regards
    Nick
    Re: Adjustable springs
    Tighten.
    RT
      For most coil-overs that have the adjustable spring perch on the bottom you loosen it. This moves the bottom of the spring down which will lower the car.
        Thanks guys, now you see the dilema.. some say up some say down
        I'll try loosen when the car gets back.
        Any other views?
        Regards
        Nick
          loosen it
          perch goes down and car goes down
          http://www.mychimaera.com
          http://www.my240z.info
            To find out, jack up the car (this makes it easier to turn the perch) and use a marker pen and make a mark above and below the perch. Now turn the perch half a turn and see what happens.
