removing window frames?
  • removing window frames?
    Hi Has any one removed the window frames from their doors and made them frameless like newer cars, if so any piccies or info on how you did it??
    Geoff
    Only cars designed with frameless windows hold them tight enough to go up and down
    If you remove the frame from a framed window , it will wobble all over the place , it will not be tight like a frame less window is
      Thanks for replying how do they do it then... have a frame inside the door to keep it ridgid??
