Ferrari OEM gauges in a Fiero
  • Ferrari OEM gauges in a Fiero
    Any reason Ferrari 355 OEM gauges would not work in a AD355 Fiero kit?
    Can't speak for the 355 kit, but I have an F40 with an 86 2.8 V6 and all gauges are oem Ferrari 328. The fuel tank sender and oil pressure sender have opposite ohm readings, so you will need the senders. I just found out from a Pennocks member that Napa has an oil pressure sender for earlier Veglia gauges, and I have one coming. It will need tweeking to give accurate readings. steve
