I just thought I would give you guys a heads up on VHT’s Wrinkle paint. I had used this stuff over 25 years ago and wanted to use it again on my current build. I wanted to paint my fake Ferrari intake with red Wrinkle paint and the oil reservoir with black. Believe it or not I still had a half a spray can of the black sitting on my garage shelf. Yep! It was over 25 years old. There was still pressure in the can but nothing would come out of the nozzle. Soooooo, I poked a hole in the can and let all the propellant out, poured it into a spray gun and used it. The part came out perfect. When I moved onto the intake I purchased a new can of VHT Wrinkle paint in red. I sprayed it the same way as the old black stuff but the finish came out lousy. I started reading around the net as well as going to VHT’s website. Many people suggest to use a heat gun or put the piece in the oven to cure at 200 degrees as well as painting the parts in the sun. After several attempts I found that process did not work well and didn’t give acceptable results. Now that I have moved onto a second can I finally figured out how to get good results.
If your part has lots of curves and angles such as my intake. Mount it to a board or something so you can move it around without touching it.
Spray a tack coat and wait 5 minutes
Spray 2 to 3 medium wet coats allowing 5 – 10 minutes between each coat.
Do not try to speed up the process by putting the item in the sun or using a heat gun. Doing so will make the paint sag and will end up causing a very small wrinkling effect.
You must build up a good layer or the paint will not wrinkle evenly or may not wrinkle at all.
If you should add to much paint and it starts to sag in places as it sets up. Move the part around and keep that from happening.
After a couple of hours you won’t need to monitor it anymore from sagging but keep it away from the heat until it fully wrinkles. Preferably overnight.
By keeping heat away from the part until it’s dry to the touch will cause the best wrinkling effect. After 24 hours the paint will be dry to the touch but will stay soft for days.
The best I can tell. If you have an area that doesn’t wrinkle to your liking. Don’t think you can touch it up. You can’t. You need to strip the whole part and start all over again.
