Prova windscreen pillars - inaccurate? Discuss...
  • Prova windscreen pillars - inaccurate? Discuss...
    Ok, so I have an early Prova tube frame car, one of the more accurate replicas, I understand.
    I think the windscreen (windshield) pillars may be wrong.
    On the genuine car, the glass goes from door frame to door frame, thus:
    And here:
Name:	Lamborghini-Countach yellow-Front-Angle-st.jpg
    This would imply that the upper face of the 'A' pillars is lower than the edge of the door frame, to allow the two to be flush once the glass is installed.
    On the Prova, the surface of the windscreen pillar is already flush with the door frame, meaning that an 'extra' line of body coloured material is created between the windscreen and the door frame, thus: Click image for larger version
ID:	389831. This car (awesome) is the Bob Fonger car recently listed on Ebay for $110,000, described as based on a 'PROVO' body from the UK, also described as moulded off a real car therefore 'accurate'. This is in no way a criticism of that car, it is epic. I wish I was even able to imagine a replica being that good... anyways, here's a couple more Prova pics. Look at where the 'A' pillar joins the roof:
    Now, the finished cars are beautifully done, and all credit to the builders, but what glass did they use? If the genuine glass is supposed to cover the 'A' pillars, which these do not, what windscreen did they use? What to do now with a Prova kit if accuracy is sought? Do I cut a genuine windscreen, or 'grind down' the pillars to allow the window to sit flush with the doors?
    Thoughts guys and girls?
    K9
    Hello? Anybody?
      Countach Windscreen
      Hi K9 , I faced the same question, I suspect that my shell is molded from a Prova, not totally sure but looks the same, it was originally supplied to me to use the replica windscreen, and had the boarder of about 3/4 " down the sides, a look that I hate. So I did some digging and found there are many windscreens out there , mine was ordered in from a Company in Australia.
      I had my window measurements before I bought the shell or the glass, so I made a template from the measurements and then took it to the then shell builder and we worked out that we could cut away the border and just leave the vertical edge of the border.
      On a real car the edge is about 1/8" thick and stands up vertically down the edge of the glass, so that's what I have done, and then I bought the glass and drew around it to make a fresh template from 4mm mdf and it fitted the shell perfectly, the only other thing I did not like was the low roof line that dropped down to the windscreen, so I have cut the A pillars and also the edge of the roof at the rear where it joins the body next to the airbox , you might be able to see the yellow glue line in one of the pics, there is a line there just behind the door that allowed me to tilt the roof up at the front and slightly down at the rear, and then glue and glass it all back together.
      You just have to be careful you don't raise the front of the roof too much , otherwise the glass becomes too short but I was able to raise the roof to the original 1070 at the Centre, and the glass still fits no problems, I have attached a couple of old pics of the roof line after the changes. Please Ignore my crazy son going for a drive, we were trying to gauge the head room available and he's 6ft 2.
      If it helps I will try to dig out the part number for the glass I have.
        Thanks for the comprehensive reply.,...
        I'm thinking that yes, I'll remove a 'slice' of the 'A' pillars to allow the glass to lay properly on the car. What did you use for the black surround around your glass? Do you have any pictures of the 'edge' on the real car, or dimensions of the roof adjustments etc, for reference please?
        Your son is, indeed, crazy. Everyone knows you can't drive a Countach in wellies.....
        K9
          I also have a Prova body and my screen edges are the lower than the roof line as the way Lambolex says he did his. I have heard that Prova bodies had the wide a-pillars but I have had two Countach bodies and both have the correct screen and a-pillar shapes.
          i can take pictures of mine once I get it into the garage in a bit.
          cheers
          don
          Prova Countach 5000QV
            Countach windscreen edges and a few other hard to get pictures
            Hi K9, I dug these out from a recent car show in nz , the red car is red not pink as cheap camera phone takes it, black car is in usa, I am yet to mount my window but was going to paint it black on the edges, also I have discovered that the old Lettraset product offers a pattern of ever decreasing size of dots just like the oem windows, so I am going to paint the edge, and then use the Lettraset to get the frosted edge.
            As I went through my collection of photos, I also found a few others that might help you ,and other builders, some are pics you just don't find on the web. It is a real car but as you can see need some tlc.
              and some more
                and two more
                  Nice job, thanks guys...
                  Those pictures are very useful, thanks. A couple of pics of the car BEFORE the window goes in would be super useful. One of the best resources I found for detail is a 17 minute youtube 'walk around' video on a genuine car. I posted about it but PM me if you can't find it.
                  Any thoughts on steering column covers for your car, I have a cunning plan on that one... LOL
                  K9
                  and two more
                    Countach Steering Column Shroud
                    Hi K9 , I will post pics when I get to that point but its going to be quite a while yet, as far as the column shroud, I am using a Toyota Soarer Column so don't really have the choice of something more like the original the Soarer is flat across the top so will not come up between the speedo and Tach not as much, but its not a major, I would rather have the memory electric tilt and telescope function working , it will make access so much easier, so what is you cunning plan to copy the original, I know Will wbnemo1, had done some work on that but that was in 2011 and I think V12al had a real one but I have not heard any more of it. I have attached a few pics.
                      and more pictures
                        Couuntach Shroud
                        and more pictures
                          and the last of then, hope it helps someone out there, I think these may have come from V12al over on lambo replica years ago
                            Holy crap! Thank you, Thank you, thank you!. My intention (which is well on the way) is to design the CAD file for the shrouds/covers, and have them 3D printed. I can then either make a mold from that one and make them available to the other Countach builders, print more and do the same, or even have the a 'negative' of the part printed (a mold) and make them that way. I haven't been able to get definitive images of the part, but these pictures are beyond helpful, thank you. I'llpost a pic of my first or second attempt at the CAD file, but I have a local design guy on board now, and we will now be able to refine the file for the 3D printer (The UPS store of all places, would you believe?). When done, I'm happy to make them available for the other guys, for the good of the forum.
                            K9
                            Be gentle with me, I'm learning a very complex (for just a cop ) program as I go along, and didn't have decent images to work from...
                              cheers
                              don
                              Has anybody tried Easton at Jemco in Texas , he supplied the bodies for the kester cars which mine is one of , my windshield goes right to the door edges , not sure where his source is . I think there were two different bodies that Prova did, the second version had the windshield with no pillars.
