Yes turbocharger and turbo is the same technically I was jus saying turbo in reference to what ppl mean by grenade the 2.5 whitch is nitrous spray like fast & furious setups or gone in 60 sec buttons that spray in. Most ppl say one thing but mean another so I was jus saying turbo in response to what cutlass 442 was saying which from what know is geared towards nitrous spray. Or as you may hear 100 shots or im running a 150 shot. Thats nitrous which will blow motors but turbochargers and superchargers are good for running constant or consistant lvls of boost I.e 5lbs or 15lbs of boost. Certain hondas built right can run 30lbs of boost. I would never do that on this 2.5. Just 5lbs of boost is sufficent for this app and no new injectors or ecm reprohramming would be needed but this. Internet breakdown which was easier to copy and paste will explain
A turbo is similar to a supercharger, except it has an exhaust housing instead of a pulley, and runs off of your exhaust gasses. As your car produces exhaust, the exhaust gas spins the turbine which causes the compressor to force air into the engine. A turbo is more efficient than a supercharger since your engine does not need to work harder to power the turbo. Because a turbo is not connected directly to the engine, it can spin much faster than a supercharger.
So basically a turbo charger just speeds up what the engine can already do, and it makes your car sound like a fighter jet. Plus working off exaust fumes with forged internals you would have to be redlining and running gears out too long to blow up a motor especially on 5lbs
