430 suspension ideas needed!
  • 430 suspension ideas needed!
    Hi all!
    I wat to put an other suspension on my build as i dont wat to use wheel spacers..
    I wanted to use a Corvette C6 setup... But I just found out it sets me back around 7k (euros), which is too much for me on this build...
    Do you guys have any cheap alternatives!? I want the calipers facing towards the B-pillar...
    Looking forward to your ideas!!!
    control arms between c5 and c6 are not that much different, rear is where most of the change has been made. I'm using c5 with 13" disks. it cost me about $800 front and back
    http://www.mychimaera.com
    http://www.my240z.info
      Ok that sounds better! I heard you can only fit Corvette rims in the hubs.... Is that correct? Is it possible to get adapters to put oem ferrari rims on them?
        I don't see any reason why you can not put an adapter on them, you will naturally change scrub radius with any adapter. The hubs are 5x4.75" or 5x120, there is plenty of room you can always redrill to something smaller but you will have to watch out for the center hub dimension to fit your rims.
