Front Mount Engine to Rear Mount (QUESTION)
  • Front Mount Engine to Rear Mount (QUESTION)
    Hello guys, I'm close to finishing my chassis and it's designed for a rear-engined car. However I find it difficult to look for a rear mounted engine here in the philippines. What I'm planning to do now is to buy a 4cyl engine + tranny from a honda civic and mount it's engine to the rear of my chassis. Is there a way to make that possible?
    Is the Honda Civic a front wheel drive car? You can pretty much use any front wheel drive engine/trans and relocate it to the rear of the car.
      yes it is a front wheel drive car. thanks for the answer btw
        I’m not familiar with Honda’s but you may be able to use the entire drive line, sub frame and suspension attached to it.
          You should buy a whole Civic and take the drive train, wire harness and every other odd and end you need to make it work on your chassis.
            thank you very much guys! for the mean time I'm going to use 4cylinder honda engines on my project, and save up money for some v8s or v12s.
              Most of the kits using those kind of engines/transmissions end up using specific suspension components, including the uprights and half shafts. My RCR SL-R would be typical. That is a lot of development on those unique parts however.
                Though I don't have much mechanical experience like others, but after watching certain videos on youtube, I know its very possible. https://www.youtube.com/watch?v=tTpTaNUv77E
                  Why would you want to trade out the Honda engine? you could build it and get alot of HP out of those engines, not to mention they sound more exotic than a V8!
                    thanks alot for the help guys! I'll post my own thread about my build as soon as I can make the chassis run with the engine.
                      If he relocates a normally front engine setup to the rear by a sub-frame/etc. won't it be more "rearward" since in the front setup it's usually between the front wheels and back a little towards the passenger cabin, so in moving the whole setup to the rear it would be rear heavy weight distribution? Also with moving the whole setup including the trans how would you then setup to continue using the transmission to shift?
                        The Honda engines (K20A, etc.) are actually slightly in front of the front wheels in the production layout, so these will become a mid-engine when moved to the rear.
                        There are various ways to set up the shifter cables but the best is probably to run the cables from the front side, hooked up to a shifter that is backward. Each of these mods reverses the shift pattern and a twice reversed pattern becomes normal again. You need to make a bracket for the shift cables coming from the front side but that isn't so hard.
                          The shifter will work just as it did with the engine in the front of the car. You are just moving it back and not turning it around or inverting it. The cables will run from the shifter to the rear instead of to the front and everything will work just the same as it did in the original position. You just need longer cables and to fabricate the cable mounts.
                            thanks guys, now I'm a little bit bothered by what Diesel Josh said, is there a way I can mount the engine in a "mid-rear" way?
                              If you use any transverse FWD engine transmission combination the engine will be slightly in front of the rear axle line. That should be what you want for weight distribution purposes. I am not sure what you mean by "mid-rear". You can use the original shifter and just mount the cable so they come from the rear of the shifter and then fabricate a mount for them at the transmission. I have done this several times and it works well. PM me if you have any more questions or email at eric@kitcarchassis.com
