How big is two big, with wheel adapters?
  • How big is two big, with wheel adapters?
    Hi, Im wanting to put a set of c6 z06 Corvette wheels on my fiero kit car. They are 19X12 in rear. I just recently discovered that the corvette is a super high offset. I wanted to know if anyone knows how long a spacer is needed in the rear, to have the wheels clear the factory strut spings.? I also want to know that if its over 4", will that be dangerous? Also considering having to stack the spacers because Its too long for one. I will probably not be using hub centric, but I will be using ET lug nuts, to center the spacer. Im not worried about how far it stick out, because Im having custom fender flares made depending on that. Thanks
